iPhone 11/11 Pro
kenvin05
Night mode is rubbish, everything turns out black most of the time
These days whenever I take pictures at night I always go back to my s10+
you cant move around, as you need to stay at the same position for 2-4sec, is depend on the how many sec you set.
thisisnotme1212
when chiu all inspect the phone, got request to take out the piece of plastic covering the front and back?
gots inspects the cameras too?
kashix
ragnarok95
Senior Moderator
Senior Moderator
iphone 11/11pro no more plastic at the back. If you see plastic at the back then you should be worried.
thisisnotme1212
I got inspect the camera. iPhone 11 Pro Max I don’t recall having plastic at the back. Only got plastic at the front screen. Afaik. I didn’t take out the front plastic.
yup. chiu ish rights. only front has.
moi think needs to remove the plastic then can check for scratches rehs.
although fans will says the glass ish immunes to scratches.
wondering if they can reject requests to remove the plastic.
sgAshton
Buying my iphone 11 yellow later... Switching over from the note 9. I hope the transition is good
kashix
Yes I checked thoroughly before agreeing to take the set. Scratches on the outer frame. Camera whether got dust. Camera whether working. Speaker working. Vibration working. All the usual stuff.
You won't go wrong with an iPhone.
Couldn’t agree more. Can’t go wrong really.
Hahahahaha maybe 山寨机 will have plastic at the back.
kokfann
Price of power bank is dirt cheap nowadays...
I'm honestly worried about the battery life only... cause mine is the base model, not the pro or the pro max. However, I know that the pro max battery is currently destroying every other flagship phones right now
teoph04
Is the iPhone 11 pro and 11 camera quality the same?
Sent from Samsung SM-N975F using GAGT
Snoweagle
I've been using iPhones since 3GS and have never had any issues with poor battery life. I can tell you even my X beats the batt life of my Note10+.
Aikon
Huh. I tried the night mode on my wife’s phone quite good leh. But u cannot move around too much otherwise u will have a blur image
They do tell you to hold still. Works like all the other brands.
