iPhone 12 pro max
leongws
How do I transfer android gmail contacts to iPhone ?
I seen YouTube guide to export Gmail contacts to Vcard & login to icloud and import the Vcard, but unfortunately there an error.
So I tried another way logining in my mail, the contacts been shown up, but unable to backup into icloud.
Anymore guide to advice please ?
I got list down the steps a few years ago. Not sure still valid or not back u can try.
spidercyj
Was watching this YouTube video and indeed some apps when you send the Dolby Vision videos you taken will look overly bright
Matrock5
I’m kinda impressed with this pro max. My last charge to 100% was on Sun Morning and been using it till now my SOT is 6h7m I’m left with 22% batt.
bryangel86
Hi guys. Would like to check if anyone of you notice a slight gap between the screen and the stainless steel band on the upper left area. In certain angle and light you could partly see whats inside. It like 1mm gap along the volume button and mute switch. Thanks.
Snoweagle
Nope, mine’s flushed all the way.
bryangel86
I could totally slide a piece of paper on it. The rest of the sides are completely intact, zero gaps. I’m worried it would affect water resistance. I got 2 units from different telco and they both have the same issue.
ragnarok95
Senior Moderator
Senior Moderator
If you see a gap, never never try to slide a piece of paper to prove it. Due to the shape edges, paper might get stuck inside. I know because it happen to my XS. I saw a small gap and try to slide a piece of paper. End up some of the paper get caught in the gap. The more you tried to remove, the more it resist and it end up dropping inside the gap. So if someone tried to take my phone apart, they will see this small piece of paper inside my XS. lol.
If you are worried, drop by to apple and let them have a look.
bryangel86
Thanks for the advice. Will wait for the other bros here on there observations on their unit. Hope to here some feedback.
Matrock5
Are u referring to this? or do you mean the main screen and the metal sides with the screen facing you while holding?
Snoweagle
kruzeryo
I immediately check my 12PM. Lucky no gap. You should get Apple to check on it.
metamofia89
Don’t need to wait for any feedbacks. Go and consult the Genius Bar for a potential defect. This is serious because the seal for the water resistance might be compromised. In future if you have a water-damage phone due to seal not being intact, you’re going to end up arguing for a lost cause. Apple will not be held accountable for any kind of water damage in their water-resistant phones.
