iPhone 12 pro max
wacko82
Finally got my Graphite 256GB iPhone 12 yesterday.
Did a restore directly from icloud using home wifi.
Total hours taken 3 hours.
All apps intact but social apps like Facebook/WhatsApp/WeChat need to manual login
took me 1 hour plus to transfer from my xs max via mac itunes.
the restore from backup is a killer sia
siandiao
Moderator
Moderator
Anyone noticed with the iPhone 12 Pro Max, most of the Qi wireless charger cannot use? Seems like the Coil on this new phone is slightly above than previous phones. My house one rounded hard to align, my car wireless charger totally cannot detect with normal position
my cygnett one doesn’t work anymore with iphone 12 pro max
wacko82
those apps that need login, will require a re-login. tracetogether also and wallet also need to update your carss. its been awhile since i log in to itunes.
siandiao
Moderator
Moderator
did phone to phone transfer from SE to 12 pro max while driving out. took about 45 minutes. almost everything still intact, apart from a few that requires revalidation of credentials
clyp1973
Can some please confirm if Dr Done can indeed transfer whatsapp messages from Android to iPhone?
It's my only hurdle before I jump
Outramkia
Yes confirm can. Just follow the instructions. Everything intact including videos. But can take some time if your chat backup is huge.
nachtsid.er
Need to buy the registered version right
Posted from PCWX using Celcom
Nevereatrice
Yes the blue looks good over time. But I got gold as I had not had gold for a long while
Blue is those must look into it and observe prolong period then will know it is prettier than gold.
Gold is those suddenly will strike your heart in a glance but will get tired of it easily.
Summary blue has much more character than gold
I have both not sure which one to keep
Sutebenu
Zzz this phone is really too big.
I hold with one hand also find it heavy and worried that I might drop it.
12Pro should be favorite among ladies, upgrade screen size from 11P and find 11PM too big.
Agreed. Not meant for one hand operation unless you have gorilla palm. Find myself using my phone less while on the move because of this, maybe it's a good thing.
evelyn_132
Not sure why ppl complaining IP12 Pro Max big. I went to recontract M1 yesterday and physically compare my Xs Pro Max with 12 Pro Max, only slight difference, not much.
Yes, as compared to XS Max, 12 pro max is just teeny weeny broader and slightly longer.
artered
I still can hold my 11 PM with one hand but this 12 PM really need 2 hands to hold since it’s so square on the sides
Parka
Shopee has this "million $ discount" promo going on now and this shop selling iPhone 12 Pro Max (256GB) at $1899 ($70 off retail).
https://shopee.sg/product/52377417/3657603099
If you have UOB one card, you get 5% (usual cash off) + 5% (new promo added for Shopee).
So total after discount is S$1709
This is certainly better than the fake 5% off from shopback.sg few days ago.
LIN_JOEL
Usually there's a capped due to item value is high.
And 5% + 5% does not calculate as 10%.
$1899 - 10% = $1709.10 But
$1899 - 5% = $1804.05 and $1804.05 -5% =$1713.85
