I have 6hrs of standby and 5hrs 35mins of usage and my battery completely died on me. Is it consider good?
LTE on? If yes, normal!!
i really hope apple would bring back the 2G option. or at least let the iPhone fall back to 2G when it is locked. this alone would drastically improve the batt standby.
Yah wish can switch off 3G too especially when I am only using IM programmea
Erm.. I thot if you totally switch mobile/cellular data to off, that means it's in 2G mode, no?!?!
i just wrote in to apple regarding keeping 2G as an option. maybe you guys can write in too, to add weight to the importance of having the feature. here's the feedback form: Apple - iPhone - Feedback
I saw my friend's iPhone 5 and his had the option to do so. He didn't have the LTE option but instead had the 3G option where if he turned off he could get 2G. Don't know if his iPhone being Starhub makes a difference but OS is definitely the same.. Think his plan doesn't have LTE, but so does mine but I still have LTE option.
If u realised, apple kinda removed the 3g toggle from iPhone 4s, it was enabled in iPhone 4 previously.
So in a way they r forcing you to use lte and its an ios thing which they should enable.
Anyway apple just fired the chief developer so good luck man! Hopefully apple wakes up their idea!
Anyone observe the yellowish tinted screen start to get whiter ?
starhub people, whoever asked for replacement few weeks ago at ps can go down directly and ask for replacement ba don't wait for calls. I today went down to try my luck and they had stocks to exchange. should be refurb stocks
