iPhone 5 Lightning Cable
yoman8
Those using the 3rd party one, mind sharing if the base of the connector is bigger than the original one? I afraid tat it would fit most of the cases. as the cutout at the port is only slightly bigger than the original one.
LobsterX
nope.... the noodle type from WCS for $27 fits the oem case I'm using.... and it's not the open type.
hawkz02
There're few type of oem available in thearket but cannot confirm. Saw ppl posting oem looking the same as the org one. The one with charging indicator is slightly bigger or I should say it squarish not rounded like the org at the lightning connector part. Some cases will not fit nicely need some work as it cannot plug in fully.
yoman8
Anyone using 3rd party cable, mind posting a pic of the connector's base ?
LobsterX
Original is priced at $28 right? why didnt u go for the original one? lol
I shall repeat again. I bought one during the period when the apple one was OOS everywhere.
Photo, kindly search the forum. I posted 2-3photo in this thread alone.
audioenslave
here u go..oem cable is as good as the original piece. mine is taken with oem cable plugged into the draco casing
Mine is able to charge via usb, socket 3 head pin charger and also sync with itunes.
pricing now shld be arnd $14-$15 and estimated to be dropping further once its the norm.
timothy
Mine is squarish type (w LED), the connector housing is slightly bigger than stock Lightning Cable but stil fit well w my case.
First time used it with Female to Male USB extension cable 1M, my iPhone prompted "The accessory you are using not supported" then unplugged it, bypass the USB extension cable, plugged direct to iPhone it work again, re-try plugged it in the USB extension cable viola since then it works without any prob but the charging duration is longer than usual. Using stock cable w USB extension cable charging time not affected. Just sharing my experience. :)
deep3lue
Anyone knows if the Lightning cable is available in town area at the moment?
aileen99
Just got a OEM cable one. It work well. Also manage to get the OEM lighting adapter.
aileen99
would be interested to know where to get and how much as well. thanks! :D
Lighting cable at 18.80 and lighting adapter at 19.90. House of mouse. Got black also
The cable like no different.
Btw I am not a seller. Just a customer. Share info only. Don't flame me. Thanks
aileen99
so are the generic oem 3rd party cables at Qoo10 or ebay okay to use now?
Might be the same quality. But I still prefer to go to shop and buy. Can test first before pay money. Qoo10 if they give spoilt item also can complain but freezing the payment.
merc
I look at those sellers in Qoo10, they will indicate "Works on ios 6.0.1".
What if one day the firmware got updated and the OEM cable doesn't work????
I wonder.............................
yoman8
Ya lo, i doubt apple so daring to make statement tat it only gives authorised 3rd party maker to produce lightning cable. not sure if the V-chip is working the same as original or juz producing a simulated signal.
