iPhone 5 Lightning Cable
magnifico
mine from the phone died..... 3 from apple store still working.
you're lucky to have so many spares. surviving on one cable is a torture.
seriously disappointing. so many years of using iPhones, and this is e first time a cable died on me. QC must be non existent these days.
Jin_GY
Hey bros, I just received my flashing lightning cable, I found out that it could only work on 0.5A USB PORT, not on the stock 1A PORT or any other 1A USB ports (it stops charging after 3mins).
The apple original one can work on any 1A port.
Please verify if u guy's 3rd party lightning cable can work on 1A ports. Thanks!
Haha, think I saw your review on the page. I ordered one to try it out.
ndleng
May I know where to purchase and how much ?
Jin_GY
http://www.qoo10.sg/gmkt.inc/Mobile/Goods/Goods.aspx?goodscode=407633064
For flashing lightning cable.
http://www.qoo10.sg/gmkt.inc/Mobile/Goods/Goods.aspx?goodscode=407604775
For adaptors.
I bought from the "adapter" seller. The quality is good n service is good as well. If cable tested not functioning, can do an exchange with seller. Bought a 0.2 n 30pin adapter, 0.2 functioning well. 30pin inconsistent, meeting seller to do an exchange
magnifico
those who have faulty cables can exchange right? must it be done only at QCD taiseng or even tradehub also can?
Punchcommins
Just bought 1 adaptor from Qoo10. Self collected from seller and found out adaptor can't fit in with my casing on. Changed to adaptor with cable and seller tested and it charge. Connected to itune and everything ok. Price $14.50 after my discount. Better to get adaptor with cable for those with casing. I'm using Cleave (Qoo10 also).
[/URL][/IMG]
ERT
None of them are apple cable la bro
That's why called OEM
Correction: These cables are NOT even OEM unless they are manufactured by FoxConn factories that produces iPhone 5.
They are replicas or fakes = 山寨版。
