iPhone 5 Lightning Cable
knethh
Lighting cable at 18.80 and lighting adapter at 19.90. House of mouse. Got black also
The cable like no different.
Btw I am not a seller. Just a customer. Share info only. Don't flame me. Thanks
thanks a lot for sharing! :D
RadEoNic
Mine is squarish type (w LED), the connector housing is slightly bigger than stock Lightning Cable but stil fit well w my case.
First time used it with Female to Male USB extension cable 1M, my iPhone prompted "The accessory you are using not supported" then unplugged it, bypass the USB extension cable, plugged direct to iPhone it work again, re-try plugged it in the USB extension cable viola since then it works without any prob but the charging duration is longer than usual. Using stock cable w USB extension cable charging time not affected. Just sharing my experience. :)
where u get this and how much is it ah?
i want one with a led indicator too so i know it's charging
timothy
Got to know abt it fr a fellow forumer who shared his purchase in this thread, got it at NEX 4th floor a shop called Ministry Of Cube, they had 2 days special price at $14 on 3 & 4 Nov, usual price was $18
Just a note, the LED indicator will stay once is plug into a charger, will not change color or off when fully charged. Good to have feature.
deep3lue
Thanks, will take a look. Too many cables in my bag not that efficient as I also have an Android phone that I use for my other line :)
Android uses micro USB cables right? Then order the lightning adapter from the Apple store instead. :)
RadEoNic
oh...like that then it's abit pointless although it will help when u're feeling for your phone in the dark...thanks anyway
Punchcommins
Adaptor with cable
Just bought 1 adaptor from Qoo10. Self collected from seller and found out adaptor can't fit in with my casing on. Changed to adaptor with cable and seller tested and it charge. Connected to itune and everything ok. Price $14.50 after my discount. Better to get adaptor with cable for those with casing. I'm using Cleave (Qoo10 also).
yoman8
Hey bros, I just received my flashing lightning cable, I found out that it could only work on 0.5A USB PORT, not on the stock 1A PORT or any other 1A USB ports (it stops charging after 3mins).
The apple original one can work on any 1A port.
Please verify if u guy's 3rd party lightning cable can work on 1A ports. Thanks!
ekardo
any pics to share??
hawkz02
What u meant by flashing lightning cable?? Mine with the led indicator work fine with both direct or USB.
messi1986
Got photo to show? What is flashing lightning cable?
hawkz02
Okay not sure on that as I only have the one same as Timothy. It work fine with direct or USB. Sync or charge both fine (tested and proven)
Lastly it came at a good price :)
hoshiyume
Can sic pictures? And seller's URL coz google cannot find
magnifico
Anyone bought e original lightning cable from apple directly? Got one for less than a month only and it died on me today. Damn frustrated by e quality. Paid such a high price but don't see betterment in it.
kingkong007
mine from the phone died..... 3 from apple store still working.
