iPhone 6 plus cracked screen : help!
gohlex
If u just bought it, within 60 days u can still get apple care+ to have it fixed, by paying accidental damage charges of $148, as screen crack is not under warranty.
http://www.apple.com/sg/shop/produc...80/applecare-for-iphone-6s-and-iphone-6s-plus
If not you may still get it fixed at Apple service center for the price of $270 or $650(if Apple deem beyond repair) like the previous bro here posted.
I just bought my iPhone 6s Plus 2 days ago, earlier it slipped my hand and drop down.. top right hand side it crack and dented alittle wif Color peel-off. What shld I do? I didn't wanna spend so much to repair on th phone as I'm Travelling soon and I didn't want it to happen. i tot of not repairing it but whenever I wanna talk on the phone it kind of cut my ear.. Please help!!
reddish22
My 1 month old 6s screen just cracked a few days ago. a.lab charge $270. i check one ah beng shop charges $148 for the glass only. if i buy apple care it will cost $228 + accidental damage service fee of $148. dont know what to do now:s11:
do you guys ah any good ah beng shop to recommend?
atomware just replied and charges $290?!
ragnarok95
Senior Moderator
Senior Moderator
Go for the A.lab charge of S$270.
aliciachoi
iPhone repair Service in Singapore
You can try at getfynd.com/iphone-repair-singapore for your screen repaired, they will travel down to your place to get it repair on the spot within 1 hour, super convenient and save time.
You can request for quotation first to know the exact price to avoid overcharge. The staff that repaired my iPhone did it very professionally and even to the extent to advise me on how to take care of my iPhone.
Highly recommended to others who are looking for iphone repair or screen repair. The whole procedure is simple and hassle free. Best still is, there is warranty covered after the repaired.
aliciachoi
you can try at getfynd.com/iphone-repair-singapore/ they travel to your place and repair the iphone on the spot, best is the price reasonable and affordable. You can request for a quotation at their website first to find out the price.
some1outthere
Pardon but is this link for real?
I spoke to Apple and they told me this is handled by alab/qcd as they ARE NOT SURE how much they'll be charging for screen repair, so Apple asked me to contact them directly.
I chatted with the apple CSO, and they confirmed that if only repair screen/glass, it's $189.
Check with some ah beng shop and they charge $100 and claim it is genuine apple glass.
Ash:
Ok. Thanks. Where are you located?
Me:Singapore
Ash:
Thanks. I can understand your need to get that fixed. I will be happy to go over the repair options for you.
Me:I noted on the apple website that repair cost for screen is $189. Is that correct?
Ash:
If it is just the glass screen, that is correct.
Me:
ok.. what are the repair options?
Ash:
If there is more damage than that, it would be up to the full out of warranty cost for repairs.
Ash:
In Singapore, you can use http://locate.apple.com to find your nearest Apple Authorized Service Provider to have the repairs done there.
Ash:
S$ 488 would be max repair cost if there is more damage than just the screen. I just wanted to clarify that.
frizee
Wah, they actually quoted you the amount...
For me, like ive said, they die die say because these repairs are done by 3rd party (or sth like that), and refused to state even an estimated amount.
Thanks!
BraveCloudy
they want your business, that's y they can lie to u.
I doubt apple weill sell the glass to some ah beng shop
hacktic
If not mistaken (as seen from those ifixit webs), the glass is stuck on LCD panel. you cant just replace the glass because that is a very tedious process. unless you dont mind "floating" glass panels
At 3rd party shops, they replace the entire thing even if your LCD is working. They keep your original LCD and probably do the tedious process slowly themselves or send it back to their supplier.
some1outthere
The ah beng mentioned something like the glue needs 3hrs to cure or something like that..
jace88
any recommendations for shops to fix cracked iPhone 6 (not the Plus or S) glass? still works but just dropped it recently and it's all cracked/ugly :( (annoyingly I had the apple battery case AND tempered glass protector; and all it did was fall off the bed)
