IPPT, IPT & RT Questions...
123qwesz
I was at maju camp and the pti said that there's a thing whereby you are able to retake that one particular station on your subsequent visit provided that you have passed all other stations including the run.
Can anyone explain how this works?
vasilli07
Partial ippt failure. U can only fail 1 static station and must retake that station within 3 months(window must be open). U won't get any $ if u pass.
123qwesz
Didn't know that there was such a thing, thanks for the information!
Jacky2000
easier for 1st year, subsequent years will get harder and harder
But is it true for tis year i manage to pass PPT1, next year PPT2, but if i did not manage to get PPT2 the next year, the PPT will lower to PPT1 the third year?
tansux
IPT -1st lesion is it a IPPT test or a normal IPT lesion.
It use to be a IPPT but I normal it has been change to a normal IPT lesion?
so we have to book a IPPT lesion first before we sign up for another 10 IPT lession ???
vasilli07
Ipt 1st session is still ippt.
hsNg_90
I have a question. I understand that regardless whether you attend RT or take IPPT, they pay you for the session you attend? Is it called service pay? If you take IPPT on a weekend, do you get paid also on top of the incentive?
vasilli07
Yes, as long as it's ippt, u get service pay.
chirppy
Guys i had a question to ask. I'm going to take my first ever ippt and unsure of what should i really do, As i am currently obese with BMI of around 27.5, is it right that i should go book for IPT? Then during the 1st IPT session, they will let me take the height and weight and if determine that i am obese, i will be put in the IPT weight-loss programme?
And how does the weight loss programme works? I look at the table below and is still confused.
wav35_
its called partial ippt failure. you can just retake that particular failed station within 3 mths provided you pass all other stations including 2.4 and have attained 12 points and above.
vasilli07
Yes. You will need to take your height and weight. If they define u as obese, then you will join the weight loss IPT. Need to lose some weight then meet the BMI they set for u. If you think u have already reach that BMI, you can book an non-ict ippt. After IPPT, go take weight/height again, if u meet the BMI, you are cleared.
And you should look at the BMI-Height table.
Kiwi8
Deluxe Member
Just want to double check. Are we required to report for IPPT 15 mins before the time, or can we still in-pro if we reach the counter 5 mins before the time?
Thanks in advance.
angcsbenny
Thanks in advance.
For bedok fcc can in pro up to 30mins after the time for ippt
vasilli07
Thanks in advance.
I believe the rules are different during weekend. You will be rejected if u inpro after the start time. Log in to ns.sg under the book ippt, then got some red wordings to tell u the inpro time during weekend.
Kiwi8
Deluxe Member
Thanks. I will reach the counter 5 mins before the time and observe the counter for a while after inpro. :)
