Is it safe?
fire
Safe lah.. use many such appliances. Just make sure it support 100-240V
yokine3a
If I do buy that, I might get it from TB.
Am drawing up a list. Am assuming that the first timer free shipping is for whole list ordered. Will have to check before submission.
Cooking rice doesn't take long so I can monitor. As for dehydrator, needs many hours, so I can't monitor .
Actually, I don't have high sugar.. but I'm thinking it should have same effect for arsenic ( rice has arsenic).
Dun go for high wattage appliances, higher risk of burning it if is lousy made.
Rice cooker I can't advise you as I dun have a low sugar rice cooker.
DragonFire
Mmmm I like to open up anything I buy online to inspect.
I have taken delivery of miswired equipment before. Or ground wire left hanging even though it isn't double insulated.
Or correctly wired, but wires hanging to screw terminal by an few cockhairs.
DragonFire
So using an adaptor is just as safe as using Singapore plug?
Propertly speaking yes. Make sure you use a grounded adapter for an appliance that should be grounded. Most adapters are missing the ground pin.
yokine3a
but rice cooker is just a rice cooker.
every brand is the same outcome (final product : which is rice is cooked).
Sellers claim it can reduce the carbs in rice, no scientific proof yet, so ppl willing to try will buy the idea.
ahnyaahnya
Long ago, decades ago, someone told me that her father's doctor advised them to use more water when cooking rice, and to throw away the excess water ( her father had diabetes). This is same thing except it makes it easier to do so
pwongkk
Yes that can be done. Problem is that I don't know how to do it..
I am old lady who never learned such stuff in school.. ( during my time, no have DnT etc)
If not see if the hardware shop people can help u. 5 min job only.
pwongkk
Yes and i want to add:
In fact it becomes safer when you do not use adapter, especially for those high power appliances like cookers and heaters. So change the plug when that appliance is going to be used long term.
Yes, I have 1 adapter melted, lucky smelled the plastic smell and quickly switched off.
Using a plug is better as there is a fuse inside.
yokine3a
Maybe eat lesser rice is easier 🥴
aCAcIAsEED
I have never bought anything on Tabao before.
I was just looking through. Am thinking of buying some electrical items. Is it safe to use their China plug with an adaptor?
Considering buying stuff like low sugar rice cooker, dehydrator ( this one will have to be on for many hours) hand blender etc
Safe or not?
a lot of foreigner working in sgp. they use their own country appliances in dom and/or shop. any news reported ?
Kaylin
no need adapter, they got same voltage as us. so far i bought small appliances like steam iron, impulse sealer, bladeless fan. so far so gd :(
