Rubick
- Jun 1, 2011
Burn in need to use the actual DAP? or any player will do? my dap can only last few hour. If not required then just use pc and turn it on during sleep hour. it had to be loud? or just normal ar? sorry ah i newbie.
Burn in with whichever you like also can.
Some say use pink noise will shorten the burn in process.
but for me i just on it and play with normal music. i put it at low volume.
What dap you using?
, and the fitting are really bad. Went to test Fitear MH334,435. Wow.. i fall in love with MH334, the sound are so smooth, make me relax and the fitting are damm comfort, I don't understand why both are CIEM version but JH version fitting are that bad but fitear design are really ... haha. No chance to try Noble, i like wizard design most. Now i only hope Roxanne turn well for my CIEM else most likely i will hoot another MH334.
