Learn how to assemble current DIY computers
20brew
When PC boot up press Del key and u see a blue screen - go to harware health and see your temps. Hmm if Acbel e2 470 should be ok for 9800GT but if 430 u may be underpowered to run it
So the underpower is causing it to hang after some time of playing ?
skaade
hi there, currently facing an issue with my system that is almost 6 years old, it keeps restarting althought there's no error msg and i think it might be due to my psu as the connection point seems loose and when its firmly connected, it will still restart as mentioned.
since that is the case, im kinda considering getting myself a new system by scrapping the old parts and salvaging things like my DVD-RW, CD-RW & HDD. Do you think I can reuse my current casing? I was thinking to change it if its cheap since it has accumulated a lot of dust.
Can any experts here recommend what to get? Just want to use it for simple surfing/photo editing/word processing and playing some games that requires 3D graphics kind. Will be great to get an idea here so that when I go to the shops, at least I know what to expect. Thank you very very much!
batuchka
X2 5000 + Biostar GF8100 = $168 (Tradepac)
2gb ddr2 KVR = $25
Seagate 320 = $71
ODD = reuse
Asus TA982 + CM 460W = $99 (Video Pro)
Palit Super HD4670 = $129
$492 in the budget end :p
Awesome for 1280 x 1024 budget gaming + low power!
skaade
X2 5000 + Biostar GF8100 = $168 (Tradepac) - is this the mobo? with casing?
2gb ddr2 KVR = $25
Seagate 320 = $71
ODD = reuse u mean HDD?
Asus TA982 + CM 460W = $99 (Video Pro) is the gfx card?
Palit Super HD4670 = $129 this one is...?
Thanks for the detailed breakdown! here's some noobie qns above in bold. All the talk about getting head chopped sounds scary so just wanna make sure. Sorry if im super noob, but i am! xp
20brew
2gb ddr2 KVR = $25
Seagate 320 = $71
Hey ya , the rest i'm not sure but the palit hd4670 should be gfx card i guess
lunloon
X2 5000 + Biostar GF8100 = $168 (Tradepac) - is this the mobo? with casing? <=== Proc with MB
2gb ddr2 KVR = $25
Seagate 320 = $71 <== This is HDD
ODD = reuse u mean HDD? <=== Optical Disk Drive
Asus TA982 + CM 460W = $99 (Video Pro) is the gfx card? <=== This is the Casing + PSU
Palit Super HD4670 = $129 this one is...? <=== This one is GFX
Just to clear doubts
kai_87
Do i need to take out the motherboard to install the new processor if I upgrade my processor from C2D to C2Q?
Thanks,
XDingDong
Hi guys,
need some help here. i'm using CM centurion 5 casing. i would like to air cool my rig better. Any idea? Just buy from sls?
batuchka
Thanks,
Yes best is you unscrew mobo out of casing to lessen risk of bending evenmore so with Intel's push pin locking mechanism for the HSF.
kai_87
But theres not guide on how to remove mobo from casing. Beside the screws, I sure that there are nut behind to tigthen the screw?
xzsnorexz
Hi all, im intending to get a new DIY computer as my current one is too old and underpowered to run Current and Future games liao,
I would mainly want a CPU that is mainly designed for gaming and a bit of overclocking.
I only have a budget of around 1k, would like to seek advice from you guys here on what parts to get, im thinking of going to Sim Lim square to buy,
but no idea on the parts since i long time nv touch IT stuff liao.
Can anyone provide some suggestions within a 1k budget?
Thanks thanks!
ic3_ED
hi all, have a few questions that i hope can be answered..
what does all the name of the motherboard and CPU mean?
eg:
Asus P5KPL-AM/PS G31/VGA/1600FSB/GBL/MATX
Intel Core 2 Duo E7300 (2.66GHz/1066/3M/Box)
what do all the numbers/letters signify?
please advise..sry if sound noob..
cheers =D
AS1
eg:
cheers =D
its the model of the device, chipset used, variation and main features.
ic3_ED
ah..okok..
then any motherboard and cpu recommandations for 8800gt? not looking at SLI, $500 caps..
merryDut
ah..okok..
Hello?? YOu got $500 budget and you are still going for 8800? Come on, there are new GPU chipset out already. If you are a die fan for nVidia, go for GTX 280 series or ATI can use 4870 to compare..
I am sure both cards wont cost more than 500 but performance wise would be much better than 8800gt.
polike
ic3 ED, don't panic. I remember going into shock when i first saw Fuwell's pricelist.
For example, Asus P5KPL-AM/PS is the name of the mobo It uses a G31 chipset. It supports up to a 1600Mhz Front Side Bus(it wil also support 533,800,1066,1333Mhz FSB), has Gigabit Lan (GBL) and is micro ATX (mATX)Micro ATX motherboards can fit in a ATX case but ATX motherboards cannot fit in a microATX case.
for processor Intel Core 2 Duo E7300 is name, 2.66Ghz is speed, 1066FSb has 3MB of L2 cache and comes in a box
Imogen
Hi everyone, I'm new here, heard that this forum offered great help, so I decided to join and seek some much-needed advice :). This would be my virgin attempt at assembling my own desktop. I would probably be heading down to Sim Lim Square to get it assembled, after I get a rough idea of the products I'd need.
I'm an about-average game user, so I don't need superbly top-of-the-line products and such. My main purpose for the desktop would be for it to run most games like COD, World of Warcraft, Sims3 smoothly without hiccup, and one that hopefully would be able to carry me into the next couple of years - service-wise.
I was wondering if anyone would be able to list down the products (with prices thx) I'd need to build my desired desktop.
Currently keen on the i5 and i7 processors so if you could somehow fit that into your recommended list, I'd appreciate that.
My budget: $1400-$1500
batuchka
Whoa average gamer can make do on something like a $700 rig ler hehe but if can splash good for you hehe
