Learn how to assemble current DIY computers
batuchka
i was thinking of using your rig.
can you state the name and the shop pls. what if i change Shapphire 1GB HD 4670 HDMI to HD4650? cos i want save more money.
what's CN 341??
Hmm actually those prices outdated and entry level rig can easily go DDR3 platform :p
1. CM 341 $53 Tradepac (PC Case)
2. Sapphire HD 5670 $146 (PC HD 4770 if in stock)
3. CM Realpower Pro $79
4. AthlonII X3 425 $105
5. Samsung DVDRW SATA $30
6. Seagate 7200.12 500 $72
7. 2GB KVR DDR3 1333 $75
8. Biostar A780L3 $84 Classic Dynasty
$644, Items 1-7 from Tradepac while Item 8 from Classic Dynasty If purpose is gaming the last thing you want to do is compromise on GPU
batuchka
gigabyte GA-P55A-UD3P + Intel i5-750 -$548
seagate 250HD -$59
sapphire HD5770 1GB vapor-X -$279
Team elite DD3-1333 3GB -$99
coolermaster550w extreme -$76
casing -$55
windows 7 home -$150
~$1266
Hi all, the specs above is what i wanna get for my gaming rig. My budget for it about 1.3k or so. My priority goes to processor and graphic for i wan to have a really good gaming experience. Fellow gurus please offer some advice. Thanks !
Err depending on resolution for games too GPU lite? Hdd, PSU and case leaves a lot to be desired as well....
jeffrey159
Hey. can i change option 2 to Sapphire HD4650??
is there cheaper price? i just need this for mid-end gaming.
Remove option 6 cos i alr have a HDD. don't need so big
batuchka, where did u check all this price? where's TradePac btw
batuchka
1. Tradepac - SLS #05-18
2. If really want to cut costs at least hit Sapphire 512 HD 4670 $108 Tradepac? At least can do 1280 x 1024// 1440 x 900 // 1366 x 768 gaming
jeffrey159
oh btw. do u know where to buy some kind of thermal paste for the processor?
i was curious about the pc case and power supply. how do u know that the PSU can fit perfectly in the pc case? some of them are big and some small that are unsuitable. how u guys check?
jarred1223
How come in MW2 and WiC, HD5670 better than HD5770?
Edit: Ignore my cockeye-ness :p
jeffrey159
when i check other forum. tradepac looks like a scam or something like that.
is PC Themes or Bell a good store??
TakeruAkimiya
Never tried Tradepac so can't say.
PCThemes has good service and is reputable ^^ Heard some negative feedback about Bell.
It's up to you who you wish to believe.
jeffrey159
anyone help me check if there is any of this in PCThemes
2. Sapphire 512 HD 4670 $108
i don't know where to check.
btw, must option 7 be KVR 1333? is there any cheaper DDR3 rams??
batuchka
The boxed processor already comes with thermal paste under the heat sink protected by layer of film
As long as a casing can house standard ATX PSU it's all good, though certain casings like SFFs may have limit on length of PSU
batuchka
Have personally bough and pointed clients to Tradepac (before rigging up for them) for exclusively AMD oriented h/w : no issues thus far :D Can bargain some more hehe
TakeruAkimiya
I feel that investing in a better TIM is worthwhile in the long run as your CPU lasts longer , no?:O.
batuchka
For stock user even light OC have peeps live off that paster that came with processor till it become dried cake liao hehe If want to but thermal paste go ahead lor
strngy
PSU
Hi, I will like to buy a new psu thinking of getting something around 500~550w any recommendation?
batuchka
Andyson F500M
Seasonic M12 520
Enermax Liberty ECO 520
Aerocool E85M 550
jeffrey159
so everything here is from TradePac except for option 8?
1. CM 341 $53 (PC Case)
Total $534
jeffrey159
lol i don't really know how bargain xD not a good talker lol
batuchka
Total $534
Yep ^^
Just ask quote as per pricelist then ask " Boss by cash wat is best price" :s13:
joeyttk
Water cooled ?
hi, I like to get some professional help to build a water cooled pc. Which shop or individual would you recommend ?
would you know if they can test run or guranatee against leakage ?
