LG G Pro 2
kelvinti
Okay.
Photo 1 is with Normal mode + Brightness at 0 (Default value).
Photo 2 is with Normal mode + Brightness at -1.
I think the default value of Btighness on G Pro 2 is too high!
It should be at the -0 as default value.
I personally like photo 2 as color is accurate as I see with my naked eyes.
The default 0 is too bright for dimmed / night shoots resulting in a washed out photo.
I took a few night photos on the street and I also prefer the result as in Photo 2.
The problem is that the set value other than the default 0 will not stick (saved). It has to be manually set again and again once you quit the camera app.
I wish that it can be saved so that I don't have to set to -0 every time I wanna take a shoot a night.
kelvinti
photo number 2
Bro! You are the right and "powerful" person to feedback to LG about the issue!.:s22::s22::s22:
They have to take your feedback seriously for sure and hope that LG will update the 0 to -0 as the new default value in the next fix/updates.
Tell them the default value of 0 doesn't represent the real color as promised and as consumers see with their naked eyes. This is a big big disappointment of G Pro 2's camera. :( The shot at night/dimmed places is washed out due to the high value of Brightness setting at 0! :(
I'm nobody and LG will ignore my feedback.:vijayadmin:
Thank you very much in advance! :)
arkaneslayer
Not sure whether it's been mentioned before, but you can change to different telco software but putting in the relevant telco sim card and do a factory reset. On reboot, it will ask you whether you want to to load according to sim settings.
Very smart of LG!
Oh I love the qslide. Smart idea again!
How to undo?
