macbook neo need help guys
cosmothecat
really i google office said same same.... KNN... but mainly only use outlook/word/excel
the sales team will only need to view the documents not so much edit on them much.
Compatible? Not at all
if you are working in a job that uses predominantly MS office for windows, even MS Office for Mac is not that compatible
the most annoying thing at office is to pass a windows office Excel spreadsheet to a colleague and they made some edits, saved, the Excel file came back with formulas and macros all broken
Compatibility issues between Mac and Windows version of MS Office:
Files created in MS Office for Mac and MS Office for Windows are generally compatible, but there are still gaps in features, add‑ins, and some advanced formatting or automation that can cause differences in behavior or appearance. For typical Word/Excel/PowerPoint use, issues are minor, but power‑user workflows on Windows do not always translate perfectly to macOS.gosoftwarebuy+2
Apps and feature set​
  • Windows has a broader app lineup: it includes Word, Excel, PowerPoint, Outlook, OneNote, plus Access and Publisher, which are not available on macOS. Workflows that depend on Access databases or Publisher layouts cannot be run natively on Office for Mac.brytesoft+1
  • Mac receives the core apps (Word, Excel, PowerPoint, Outlook, OneNote, Teams) but lacks some of the “enterprise” and niche components present on Windows editions.gosoftwarebuy+1
Excel, macros, and add‑ins​
  • Excel on Windows supports full Power Pivot, Data Models, complete Power Query editing, and richer integration with external data sources, while the Mac version has limited Power Query and no Power Pivot/Data Model support. Large analytics models that rely on these features will not work the same on Mac.parallels+1
  • VBA macros exist on both platforms, but COM/VSTO add‑ins and ActiveX controls are Windows‑only; many industry templates and legacy Excel tools depend on those Windows‑only technologies.brytesoft+1
Formatting, fonts, and UI behavior​
  • The document formats (DOCX/XLSX/PPTX) are the same, but differences in available fonts, font rendering, and printing systems between macOS and Windows can lead to small layout shifts (line breaks, page breaks, spacing) when sharing files cross‑platform. This is most noticeable in tightly formatted reports, forms, or slide decks.softkeys+2
  • The ribbon and interface are similar but not identical; some commands live in different menus, and certain Windows‑only customization options (e.g., deeper ribbon or toolbar customization, some legacy dialogs) are missing on Mac.learn.microsoft+1
Outlook and integration​
  • Outlook for Windows still offers more advanced features and integrations, especially with Exchange, SharePoint, and enterprise add‑ins, than Outlook for Mac. Rules, calendar views, and group features may not match 1:1 across platforms.microsoft+1
  • Office on Windows has deeper OS‑level integration (e.g., with Active Directory, some OneDrive/SharePoint sync behaviors, and Windows authentication), whereas the Mac version integrates better with macOS features like Spotlight or AppleScript/Automator instead.softkeys+1
Cross‑platform collaboration impact​
  • In mixed Mac/Windows teams, basic co‑authoring and file exchange usually work fine, but advanced Excel models, Access‑based tools, Windows‑only add‑ins, and some layout‑sensitive documents are the main sources of friction. Testing critical templates on both platforms and standardizing on the “lowest common denominator” of features reduces surprises.parallels+2
HelIoo
if u are not from IT, i think best to pass to your IT department to validate and don't follow your boss instruction.
i'm sure your IT department will not want to suddenly support mac and see mac in their environment without them knowing in advance.
Mephist0pheLes
my boss is asking me to look up macbook neo the base model.
3 units
purely for office work email/work
we will also be needing ms office as outlook/word/excel is what we use daily.
my boss just ask me to check on compatibility with our workflow and whatnot.
add on ms office i dont see any problems.
can guys give me some pointers and input?
i ask u for inputs, u ask ppl online who dunno about our workflow for what?
come to my room now.
hardwater
must check company roadmap if they will adopt new third party systems - if yes, will they support mac or not.
if technical support is outsourced, contract got state will support mac or not.
better consult with the it dept else you will be the scapegoat next time.
ragnarok95
Senior Moderator
Senior Moderator
Why are we helping you to do your job for free?????????
trento
i dont think my office uses ms access at all.
so far we only use ms outlook word excel powerpoint 1-2 back we got canva
i dont think the sales team need to use complex macros
advanced add on? at the most adobe reader?
yes this i understand interface and shortcuts are diff coz no matter what its pc and mac
Then neo will be good for your company
deepblue_82
no real roadmap.. they only know this that not working call me...
small company 20 ppl... ya i also email to the IT guy already
