macOS Big Sur Now Available!
boba_fett
I’m going to spend my weekend and do a clean install update. My Safari has been stuttering a lot when I’m just watching twitch.
Currently using a 2015 13”mbp. Gotta dong until 2021 than I will change to the silicon 💻
reddevil0728
If you plan to upgrade next year, might as well just update rather than doing a clean one.
Doesn’t seem to be worth the effort
boba_fett
Most of my things are in cloud. So not much to back up anyway. I still gotta live with my device for 1 year, need to make it usable haha
faithsilence
Updated! Seems alright for now lol Safari can play Youtube 4k LIAO
firesong
Deluxe Member
I figured what I don't like about the visuals. It wasn't obvious until I went to look for it.
The really huge top bars that take up far too much space. It's almost as if they are hinting at a touchscreen Mac in the future.
I guess it is because the apps I also use (Including MS Office) haven't been updated to the new design language, so that poses another set of problems altogether.
kamsani0
After installing about 2 hours ago, almost all apps are very slow too open and almost non responsive.
Damn freaking apple monkeys! First time this major update broke everything.
Someone needs to slap Craig Federighi and his team. All fat and lazy from big bonus and stock options, slacking everywhere!
discoburg
Anyone know why a folder of bookmarks shows the icons of the books marks in it and some folder just show a folder icon?
teoma
backup ur data first, try upgrade first. if got problem, then do a fresh install.
Data is always backed up, just in case, since you never know when it will fail. But definitely good advise for those considering!
KoChi
just installed in my mbp and so far everything seem fine.. is there a way I can make the widget permanently display?
Kwein
What apps?
So far all my Adobe cc softwares runs smoother than catalina
szeli
why so angry? :s22: if really fat n lazy they won't release updates every year liao.
cause of e issues:
https://arstechnica.com/gadgets/202...-temporary-slowdown-in-even-non-big-sur-macs/
manofsorrows
Fresh installed from scratch. Erased my sdd. Booted from usb. Reinstalled everything and restored my files. All good now.
twosix
https://www.techradar.com/sg/how-to/macos-11-big-sur-problems-how-to-fix-the-most-common-issues
How to fix macOS Big Sur install problems
If your macOS Big Sur problem is in installing the operating system, first make sure you check out our how to download and install macOS Big Sur guide, which will take you through the steps you need to take to safely install the new operating system.
First of all, you'll want to make sure you have a Mac that can run macOS Catalina. The following Macs are compatible:
12-inch MacBook (2015 and later)
MacBook Air (2013 and later)
MacBook Pro (Late 2013 and later)
Mac mini (2014 and later)
iMac (2014 and later)
iMac Pro (all models)
Mac Pro (2013 and later)
When you have a compatible Mac and the macOS Big Sur download completes, but there’s no prompt for the installation to continue, then search in your Mac’s application folder for a file called 'Install macOS 11'. Double-clicking the file should begin installation.
If you encounter the macOS Big Sur problem where the installation fails due to low disk space, simply restart your Mac and press Control + R while it’s booting to enter the Recovery mode. Select ‘Disk boot’ to boot normally, then remove unnecessary files to make space.
macOS Big Sur is stuck on 'Setting Up Your Mac'
If you have installed macOS Big Sur, but then your Mac gets stuck on the 'Setting Up Your Mac' message, you'll need to force a reboot of your Mac or MacBook. Don't worry, the 'Setting Up Your Mac' message means the update is finished, so you won't lose any data or damage anything by restarting your Mac.
To do so, press and hold down the power button for a few seconds until the Mac or MacBook turns off. Wait a few more seconds, then turn it back on. Your Mac or MacBook should now boot into macOS Big Sur successfully.
gnixer
same for me. fix the close lid problem.
previously when i close lid, it will drain the battery until i open the next day.
ahsiao80
Managed to upgrade :s12: of cos not without any hiccups but solved easily anyway :s13:
manics
cannot get it for my mac mini late 2012. looks like i have to get the new Mac Mini. haha
