Max tv size for hdb
W3isheng
Bigger is always better ma. Don’t know why some people just so against it.
I’m running a 135 inch projector screen, sitting distance is around 2-2.5m max.
I only can say 1 word, SHIOK
Lss
Does the back of the screen heat up?
chuah23
Hmm…i use projector so easier to move around ….and I think also can project up to 100?
W3isheng
This one projector screen, the only think that heat up is my projector on the floor.
when I put the screen down it’s rows of container behind for sotrage
Now it’s 3x5, waiting for another 5 of this container to reach.
mxkxmx
Thailand TV prices at Big C.
SGD $355 to $395
comcrepe
I bought a 75 inch tcl tv cos it was deemed good value.
after 4 years, the screen is starting to show some white blocks.
will never buy tcl again, not because of the white blocks appearing but because the picture quality is poor.
Lss
Was thinking was projector screen in front of display cabinet but concerned it will cause extra heat and damage the contents of the cabinet.
W3isheng
so far mine ok leh
doubt it’s that much heat also. The projector itself also not that hot, how hot can the projected light be?
matrix05
I am not referring to the fitting size of the lift.
I don't have info about large TV measurements, but did below info may be useful for you.
Need the width (1.1m) and height (?) of the lift. Depth 1.4 m is quite sufficient, for now.
All major brands have 100" , by next yr, 100" may reach consumer friendly price, $1K.
Cyborg
Hope this helps.....
standarture
Most content is 1080p compressed. Big screen make it look worse. Also, the whole screen should fit in your FOV nicely.
