MBP Battery Swelling
hereiam7788
Was told that even the Mac will stop charging by itself, but overtime, that feature will be degraded hence this issue.
Guess this is not very uncommon...
Yes. It happened to mine. Just changed battery last year. One year time after that now the battery is already bloated.
hclee01
Hi,
I noticed that my macBook Air cannot be closed properly when i close the monitor and the keyboard looks a little dented. Suspect that it may be battery bloated due to extensive usage for the last 2 years WFH. Mine is Macbook Air 13" 2018 version. I have scheduled for an appointment this Friday morning at Apple store Orchard for checks. If it is assessed to be bloated battery problem and need to replace, any idea the time taken before the macbook can be returned to me? Any possibility that I can get my macbook back on next Monday evening? Thanks!
szeli
Hi,
as always, go early like opening time 11am should be able to get back within a few hrs if it’s only a batt change
reddevil0728
Hi,
I wouldn’t bet on it. May take about a week
hclee01
Thanks. My slot is at 11am. It happened to me a few years back when I bought it to ALab at PS. It took them around 2 days to replace and return to me on the 3rd day. I am okay if they need 2 days to service it as I need the laptop on Tuesday.
reddevil0728
Not sure about the weekends
VodkaPear
Just to check, does replacing battery for MacBook Pro late 2016 Touch Bar = replacing the whole bottom part?
which means including keyboard and etc??
reddevil0728
i believe if you go Apple, if there is a need to replace battery and is covered by the warranty, they will just change all the parts to get it done
firesong
Deluxe Member
Can confirm it's a whole bottom case replacement.
Just had mine changed a couple of weeks back.
So bottom case + touchpad + keyboard + touch bar + battery replaced. And a very expensive repair bill.
VodkaPear
Can check how much? Cuz my mbp late 2016 has no more warranty left.
firesong
Deluxe Member
Redacting my replacement serial number.
With GST, about $640. It's not really worth it. For perspective, it's 1/2 the price of a M1 MacBook Air.
anthonygreenisreal
yeah not worth it sia. Might as well sell as it is for parts. At least got a few hundred bucks then use the money to subsidise new Macbook Air M1. you get newer next gen level processor.
