Microsoft's Surface
thec00l
Hi,
Where can i get the "first part" (3pin plug to the block) of the adapter? Or do i need to a brand new set of adapter just for the first part?
thanks!
yoohoo
for usage to do sch projects, normal serving internet and watching dramas...do i need a surface pro 4? or 3 will do?
finalforce
If your projects are just Word and PowerPoint, then Surface 3 will do. Note that non pro series don't come with the pen. You can use the Pro 4 pen on Surface 3 though!
charizard1987
I'm considering a second hand sp3 i5 8gb or new sp4 i5 4gb. Want to ask if sp3 still have issue with heating issue? I just mainly for torrent, office, and mt4, which I think sp3 can meet my daily task. I only concern with heat.
Milkshaked
you can check out my listing . im selling a brand new SP3 i5 for 1099.
Syraxius
i bought surface pro 4 type cover and the surface pro 4 pen :D and i'm lovin it! :D
edit: but i dropped my sp3 and now the glass popped out and there's a dent and i have no idea how ot fix it :(
cwsamuel
If buying the surface pro 4 in Singapore is there international warranty or is it only a local warranty?
arcaninx
Surface 3 pen is hard to find. I refuse to get surface 4 pen as it is more expensive. Any idea where have stocks?
Syraxius
When I got my SP4 pen at the Microsoft website, it was listed as the same price as the SP3 pen. The SP4 pen feels good to hold and the tip is interchangeable so it's worth it anyway
MonkeyBoyoh
Am now looking at the Surface 4, I just went to test it, it is really good...and functions fast as well.
wiwi86
anyone has recommendation on what and where to get tempered glass screen protector for surface pro 4?
Syraxius
Anyone using SP4 type cover with SP3 like me?
When the cover is folded back completely, and I try to turn on my system (from standby), the screen will turn on and immediately turn off, like as if the SP3 thinks that the type cover is folded close at the front instead.
I can only turn on my system when I move the type cover away from the back of the system. I presume type cover detection is based on magnetism, and somehow the magnetism is strong enough for my SP3 to think that the cover is closed in front and not folded back?
Apparatus
Re
Anyone knows where to buy the MS SP3 ac charging adapter here? I've checked with CHALLENGER and HN and they have no stock.
I've ordered 1 pic from MS Store online but it'll sure to take weeks to come. Meantime I need one urgently as my current one is having intermittent power supply problem
Thanks
Intrinion
Senior Moderator
Senior Moderator
Thanks
Hello!
Sorry to hear about your adapter.
Your best shot would be either to head to simlim / funan and check with retailers there
create a wtb /searching thread here
Or
Look through listings on trezo & carousell
Will look out for you if i am in the vicinity of a tech retailer
Cheers
mudxblood
Thanks
The SP3 adapter is readily available at most large stores like Harvey Norman and Challenger. Have u checked out these places?
The SP3 and SP4 both use same adapter
Sent from Huawei NEXUS 6P using GAGT
