i leave auto for most thing cos i nt into OC
lol abit wasted if no oc.
mine i oc till 3.8ghz. just nice. still quite cool
cos for games, oc = no diff as benchmarked by review sites. unless u just want to see high numbers
lol loading faster wor where got no diff
yeah.. I also quite shock coz I try first at 1.26 then stable.. then lower abit to 1.2562 then still stable.. but my temp is around 81-85.
review sites say only fps 1-2 faster...
according to the others who successfully done it, supposed to get 70+ at load max and idle temp of 45max @ 4ghz....otherwise means somewhere nt done right liao...
44-45 is my idle temp. do you guys on those speedstep on bios after you OC?
ionicle. you're load temp is 79c right? what thermal paste are you using? I'm using sflex fan also on my megashadow but my exhaust fan is xigmatex 140mm.
i think if according to them, ur temps still wrong...their load @ 4ghz is only 60+ to almost 70?
wa u making me itchy lei, i feel like really making sure its the chip before i start taking things apart! ion u free bo? i bring my chip to u, slap it in bootup, if mega cannot tame it below the right temp means its the chip, kindly proceed to OC it as much as u can until u fry it so i can RMA it
I'm also thinking that my temp a bit high compare to others. maybe others got on aircon so lower temp..
u can try to fry the IMC in the chip
If open air testing still the same temps, high chances the cpu at fault. Noctua cant be that bad
