[Monitor] Crossover IPS LCD 27 inches
HPY090909
errm can anyone summarize which is the best one to get for my MSI GTX560 ti ?
i read the initial pages than gave up...too many pages liow
btw no vesa mounts for wall mounting or desktop arm mounting ?
i1magic
Basically very simple ....
Do you need Pivot?
If Yes => Crossover 27Q Pivot
If No => Any of the models out there also can.
Cheapest would be Achieva Shimian from Gmarket. You can do a search there. Ebay has also .. but more expensive.
HPY090909
Do you need Pivot?
got vesa mount ?
eunjae
hi guys need help.
does the tempered glass ver have bezel.
cuz I think red-cap shipped the wrong type to me.
I assumed the tempered ver would be a single piece of glass on the front of the lcd?
eun
kaze-no-koe
anyone bought Achieva Shimian?
is there any difference in the size of the bezel compared to crossover?
jiewei13
hi guys need help.
eun
I ordered the tempered glass from redcap too. And I can't tell what I've gotten. Mine came with a bezel.
eunjae
plastic bezel?
shouldn't the glass be like the cinema display or something
mofuscherub
I just got my Crossover monitor from Happymall, delivered to my place. However, the ac/dc adapter he gave me is faulty thus not able to power up the monitor. Anyone know where to buy it from and around how much? Thanks.
i1magic
I suggest you could bring the adapter down to SLS and SLT to find it. Did you inform the seller about this? Are they going to send you a replacement?
i1magic
Do you need Pivot?
got vesa mount ?
I can't say for the rest ... but for Crossover ... it is vesa mount ready.
i1magic
I found this ... not sure it'll work ... but those interested can try ...
Item : 3-in-1 Mini Displayport to DisplayPort, HDMI & DVI-D
Price : About SGD$13.50
Source :
3 in1 Mini Displayport to DP HDMI DVI-D 24+5 Adapter Cable For Macbook Pro Air | eBay
mofuscherub
Happymall say must charge for replacement. Anyway, I went down to SLT and they found nothing wrong with the adapter. I am now asking Happymall for an exchange. Sibei sianz.
masotime
Second this. I've been badly burned over the whole issue regarding dual link already. PLEASE TAKE NOTE OF THIS! Don't dream that anything other than an active adapter will allow you to connect a non dual-link DVI port to these monitors. IT WILL NOT WORK.
you will need an ACTIVE adapter to even have a chance of it displaying. Said this many times already. I'll just put a link up to make sure people understand what I'm talking about:
Mini DisplayPort to Dual-Link DVI Adapter - Apple Store (U.S.)
as you can see it requires additional power from the usb.
windwaver
How do you know your monitor is faulty since the power brick is working?
