[Monitor] Crossover IPS LCD 27 inches
Swiftbladez
Wrong tracking number given by the sender.. or maybe he send to the wrong person ****..
wouldn't the tracking site say where the destination is?
anyways, just relax. can call if you worried lor. or ownself go self-collect
ry0suk1
i check with speedpost, the item was send to a pasir ris but i stay at clementi, and the name on the item dont belong to me...
the person had sent to the wrong person or given me the wrong tracking number...
MasK
I just collected my set from a bro here who wanted to sell his.
Love the amount of space ya got to work with!!
i1magic
Sorry.. just wanna clarify, does the seller check the panels for DP before shipping? Because I know the gmarket HappyMall seller does that for the PCBANK monitors.
I mean.. $50 cheaper and you're pretty much guaranteed that there will be no DPs.. the only downside is that the monitor doesn't look at good. I feel they both use the same panels though (batch is questionable though..)
Seriously ... I don't know which seller will check for DP.
If that is your concern, not to worry ... Happy Mall in Gmarket sells CrossOver and Achieva Shimian monitor as well. And his pricing is very competitive. I almost ordered from them.
To me ... buying online is a gamble .... so even if they promise no DP ... but they'll still require that we bear the shipping charges back for the exchange right?
Or are they going to bear the charges for shipping it back to them for exchange?
MasK
Think about this. The fact that Gmarket sells "perfect pixel" monitors with DP tests at additional costs.. it only means that non-"perfect pixel" monitors will be bound to have defect pixels since the good ones are already set aside by buyers willing to pay extra.
Anyways, mine has 1 stuck pixel. It's blue in colour and only visible with black background and when you're close. Very reasonable I must say :)
Anyone got any idea how long these cheap panels will last? :p
MasK
Actually I am not so worried how long will the panel last. I am more worried about the power brick. :s13:
Yeah.. that is one lightweight brick. But anyways, I'm pretty sure you can find a replacement for that brick.
Did ya guys notice all the stuff printed on the box? I totally LOLed at it! :s22:
ry0suk1
No reply from happymall 1 day liao.. How can i request for refund from from gmarket??? Or i have to request from seller?? Tracking there does not show deliver address
ry0suk1
Anyone tell me what to do?? Seller no reply, should i contact gmarket to request for refund? Or wait for reply??
Swiftbladez
try calling up the shipping company? with your tracking number you may be able to go collect it or something.
EDIT: oh just read your previous post. You have to give it a few days and if you've contacted happymall during the weekends, he's not going to reply. most of these sellers work only on weekdays.
ry0suk1
so how?? wait till monday? or i just submit the non-receipt claim to gmarket for refund?
i have the item address and name of receipent that attach with the tracking number he given me... as i had already check with speedpost..
i1magic
Which brand did you get? The one I got is Crossover ... and on the box it printed "HDMI" .... LOL!!
i1magic
Yah ... the screen should last ... but not sure about the electronic boards in the monitor. As for the power brick ... should not be too difficult to find a replacement.
Can anybody confirm that LG or Samsung monitor uses similar adapter connector?
i1magic
Their response over weekends are usually slower. Maybe they don't work on weekends. Think wait till Monday or probably Tuesday ... if no reply .. then you can start to do something.
How did you pay for your purchase? PayPal? Or via credit card directly?
benyee90
hi guy! sry if is a repeat question.
i look around for a mini display to dvi, it seems theres only up to a maximum 1080p. any other peeps can go up further to 2560x1440?
thanks
i1magic
thanks
Are you using it for Windows PC or Mac?
MasK
Yea, it's the same one... some funny stuffs:
-HDMI
-FUll HD
-HDTV
-Analog TV
-PIP PBP POP
-HD1080P
-SPDIF
:s13::s13::s13:
