Kitaro9202
- Aug 24, 2007
Some bad reviews about this brand
Dk should i get or buy aoc or dell
Ok. Glad that both monitor lasted till almost 4yrs. After the small hiccups on one of the monitor about 1.5yrs mark .... now the other monitor is having a slight issue.
Please see video for the fault.
even if you buy a renowned brand monitor you are paying for better support, doesn't mean it won't fail you...
currently no single graphic card can push 4k highend game at max detail near 60fps
still need dual card
unless tone down details
Seems like the GTX1080 gfx card can.
does anyone own a crossover 27v? $522 on qoo10. Would like to know your input, thanks guys
Wah lau ...... 我中毒了. After watching this ....
Qoo10 selling about $970!
http://list.qoo10.sg/item/WASABI-MA...UHD490-REAL-4K-SERIES-40-43-49-INCH/426008568
I actually measure and my table can fit!! My table has a top shelf and it is 700mm. The 49" monitor is 678mm!
When you play game, do you play at 4K or 2K or Full HD?
Personally, I would rather go for Dell U2717D @ $735 with 5yrs warranty on-site. This model has very thin bezel too.
alright thanks. I'll keep that into consideration![]()
@i1magic Hehe now I itchy wanna get a curved 4k 50-55" "monitor". Anyway heads up, you will have so much screen real estate that windows management will be a challenge, windows 10 is quite good but I use another program to help out more.
hello.. can anyone advise which model best for 27" 1440p from crossover? and which online site to buy?
thanks
