[Monitor] Dell U3415W
Tsting
Sorry... just a little OT.
Have a OEM GTX 745
connections available :Dual Link DVI-D, HDMI, VGA
"3840x2160 at 30Hz or 4096x2160 at 24Hz supported over HDMI. 4096x2160 (including 3840x2160) at 60Hz supported over Displayport. Support for 4k tiled MST displays requires 326.19 driver or later."
Does it mean to get the best out of this monitor, would be to use the Dual Link DIV-D ?
oric1
Have a OEM GTX 745
My card also got dual dink DVI port but unfortunately this monitor does not have any DVI port.
Goodshot
Hmm , actually hdmi and dp is better, dvi is abit old tech liao le
NCMK
Dell is coming next Monday to collect the 2 sets of U3415w and issue a refund. Wonder if anyone has a perfect panel?
watchy
SOrry OOT abit
After following U3415W for some time.... I started to get poisonned by this:
Philips BDM4065UC
4K 40" VA Panel (not TV).... this is great size for 4k monitor
Any review? and the price is only about 100+ more than U3415W.
zXioNGz
my one bleed all 4 corners. looks like no "bleed" :s13:
Luckily I don't like to do much stuffs in pitch black room, but I do notice blb at 4 corners at times, but it doesn't bothers me so I give it a pass. Like I mentioned, no point exchanging now as current revision same issues, wait for 6 months or a year later and exchange you will see better revision, happened on my U2713hm
royfrosty
SOrry OOT abit
Philips BDM4065UC
I saw that monitor. It rox for a 4k panel. One should take a look first before a u3415w.
The screen estate is darn big. No ips glow. But if you were to see it from distance this guy rox.
mnemo_05
this thread is poison.. only got my u2913wm less than a year ago now thinking of selling it.. >.<
zXioNGz
Actually it might be too big to be comfortable, unless you don't mind swaying your head around often, imo U3415W might be the perfect size per distance as it's 27inch on vertical, but this is subjective. Until I take a look at it personally since its same diagonally
zXioNGz
siao.. gpu no display port out.
so left hdmi
Then you must check your gpu got support hdmi 2.0 if not it will run at 30hz nia. This is what happened when I use my adapter for my laptop's mDP to Monitor HDMI
oric1
If I'm not into gaming, mostly using for work, at 30Hz any issue displaying 3440x1440? Will my screen flicker?
Tsting
No hdmi2.0
only hdmi
if only using for work (word processing etc), and youtube watching, will 30hz be that bad?
zXioNGz
No hdmi2.0
only hdmi
I'm not sure will it flicker most probably not as I don't notice it.
But 30hz is SUPER bad, you can feel and actually see the lag, as you move your mouse or scrolling around Web pages or doc process. For Video watching it might be okay, as most movies and videos are recorded at just 23 to 29 frames.
For normal usage, like browsing etc definitely a no.
oric1
I think the HDMI on my card is 1.4, as HDMI 2.0 is so expensive ($500+?), any recommendation for card with DisplayPort?
zXioNGz
Not sure about hdmi 2.0 cable pricing haha, don't have those $10 ones?
Card all the new GTX 900 series have it, the latest and cheaper Gtx 960 has 4 dispayport for the reference model
