hi, can you share ur config for the router?
i just got my ONT installed and Myrepublic connection running, but i can only achieve around 290mpbs to 300mpbs on speedtest.net, all connection are wired, but if i connect directly to the alcatel modem i get around 800 to 850mpbs? so i suspect the issue is with asus router something misconfig.
thanks
There's nothing done other than restore to factory settings after updating the firmware using Merlin's firmware.
And I do a manual reboot of the router after updating
