MyRepublic fibre - Part 4
raguraman
My AC68U router CPU temperature is always 100C-105C, although it is well ventilated. Can someone help to check yours please ? Probably I may need to take it to ASUS support.
To Check:
On Stock firmware, Enable telnet in Administration>System>Apply
Telnet to your router, login as admin and issue the following command
cat /proc/dmu/temperature
On Merlin firmware, Please go to Tools>Sysinfo and you can find the details at the bottom.
Thanks in advance :).
Ah-Pin-Kor
To Check:
Mine is around 86C.
Are you overclocking your AC68U?
What version is your CFE?
raguraman
Mine is around 86C.
Thanks for your quick response Bro.
No, I am not overclocking. I observed high temperatures in Merlin and TomatoUSB (Shibby). So switched back to stock ( 3.0.0.4.376_1663). Still same status !!
Just Me
To Check:
That kind of temp can fry eggs liow. My n66u is always hovering around 60 or less
maylyn
ryanseah
Quick question:
I just got my 1Gbps upgrade today. When I connect directly to the router, Speedtest shows 900+ for dl. But once I switch to wireless, it's a pathetic 20+Mbps.
Is the router my bottleneck since I'm using a N66u? Or is there some other setting I need to do? Thanks!
danxiaogui86
danxiaogui86
Quick question:
Wireless issue. your device adapter not good enough.
Do use the 5GHz band too.
danxiaogui86
I'm using an Intel AC 3160 adaptor on my laptop, and on the 5Ghz band, any suggestions on what settings i can try?
It might sound silly, but does your 2.4 and 5 ghz have seperate SSID or are they the same.
If the same, your one might connect to 2.4Ghz as it have stronger signal.
ryanseah
Haha nah, they have separate SSIDs
Just puzzled why the WiFi is so slow, wonder if I need to change my Intel 3160 or my N66u router...or both?!?!
xRenol
Despite having Intel AC 3160 adapter running at 802.11ac but your ASUS N66U router is not on 802.11ac. Thus, it will still fall back to 802.11n protocol.
One need to have both router and adapter to be on 802.11ac to utilize the ac capability.
ryanseah
Understood, but even so, using 802.11n can only get 20+MBps? Don't think so right? :(
