MyRepublic fibre - Part 4
summersky1986
Anyone having problems with the Home Voice service?
Every few days, I will not be able to call back to my line.
It will be a very short connecting tone, probably about half a second to a second, and then it becomes an engaged tone.
From home, I will not be able to dial out, no ring tone.
All the 4 lights on the Grandstream is on.
I am also aware that powering it down, wait for 2 seconds, and then plugging it back will solve the problem.
However, this is happening too often... every few days, I will get this problem. For example, this is the 3rd time this week.
Mum at home not able to receive calls, she will not be able to call out.
And I am not expecting a 70+ year old lady to know what to do, when it happens.
Another problem is calling in from overseas.
I have tried calling in but it never is able to connect.
Tried from Sri Lanka (Etisalat), Malaysia (Celcom), Canada (not too sure). All unable to connect to my number. All above at mobile lines, and using conventional lines, not data.
As I also have Pfingo service, I tried calling as well, and the same as above.
My wife, who works in an MNC, uses VoIP service in office (from which provider I have no idea)
She is also unable to call home, but calling any mobile or 6xxx number is ok.
can someone look into the above 2 problems?
So problematic, lucky I never apply for home voice :eek:
Demori
Think they mentioned something about it few days ago. Lucky I stopped using home phone lines nowadays zzz.
Btw, I heard someone was able to Teleport Chromecast by forcing it to go through the router's MR DNS? Anyone can confirm? Don't wanna spend money for nothing :s13:
Callandor
Anyone having issue trying to connect to steamcommunity.com? also my steam store page is down. If I use 3G, it's fine. Already rebooted computer and router.
Triaz881
Think your 3g is running a cached version, even news websites are reporting a ddos on steam and origin. zzz been trying for last 2 hours still cannot buy stuff.
Ultravox
If you are facing homevoice issue, kindly attempt to off and on ONT, adapter and router. If the above solution doesn't fix the issue, let me know how many green light is visible on the adapter and if needed we can send someone down for replacement.
My green light for "phone" is OFF.
Still no tone after on/off, change phone and change cable.
Have been like this for 2 weeks.
Please help..... C1001266
xRenol
I encountered no internet connection via wired but wifi is okay.
I connect directly to the ONT using the same Ethernet cable and is working.
Anyone encounter the same issue?
nyquist_ty
I am having same problem accessing steamcommunity.com. It appears to be a routing issue because Starhub mobile BB is fine. It cannot be a cached version also because I can access the Steam community market that is very active and data updated every few second. Also other websites are reporting that the website is UP.
Appreciate any resolution please... :(
winguy
Are there subscription charges for Home Voice from Jan 2014 onwards?
nyquist_ty
Update:steamcommunity is up. :D
sandyph
hi, just installed MyRepublic today
forgot to check the teleport before the guy left, just now check and all the page (hulu/netflix/premierleaguepass) said that I cant connect because Im not in US/NZ.
any setting I need to done on my PC to allow teleport to run ?
edit.
ignore that, stupid me still using Google DNS. working fine now :)
xRenol
Currently I got no Internet connection on both wired and wireless connection with Dynamic and Static IP.
