(NAS) D-Link DNS-320L
albertlee
Challenger upped the price to $159 for non-member, member one is still $99.
Desmond_
High Honorary Member
anyone need help to purchase from challenger, i (member) can help... free but self collect near my place :)
jeffprobst
need help. i am using 320l with wd red hdd inserted
the NAS itself can detect the hdd, as there is a blue light indicator.
however i am unable to detect any device when i try to install using the installation disc.
my set up, using home plug as the main modem is not in my room
Aztch home plug, wired to my NAS
or should i use a switcher for it?
jeffprobst
okay got it apparently Aztech homeplug make it unable to read. i have to use a switcher
jeffprobst
sorry guys just to check.
how to i assign the directory of the file i download from bittorrent to?
apparently when i download finish, my main computer, i will not see the folder.
but when i use a third party computer that connect to my network, i can see the p2p folder.
would appreciate if someone coudl teach me how to lock folder.
albertlee
IIRC starting from firmware 2.01 onward, P2P folder is hidden from samba view but it is accessible via Shared Folder. In short just create a Shared Folder pointing to actual p2p folder and assign permission accordingly.
jeffprobst
lol dun understand. :s13:
how do i do the pointing?
jeffprobst
map the network drive from my computer as how you would do for your nas except point it to the p2p folder specifically
ok will trie to do it. i actually anyhow set up until the drive work also :s13:
update, got it to work
thanks for the guide :D
jeffprobst
is it normal for my BT to reset to zero
everytime i switch off the NAS or internet connection?
khai19
what do you mean reset to zero? I would note that the BT app is rather buggy. But leaving it alone and in the long run seems to get the job done. I restart the share centre when it seems to be stuck though
albertlee
My advice is to dump the inbuilt BT client and switch to Transmission instead, the former can't even be use for seeding if one has account on private sites.
LX2010
anyone has a guide on how to install transmission? i tried using DNS-320 -FunPlug 0.7 + Transmission
But i ended up getting this error which floods the transmission log and makes it hang up. "tr_crypto error:24064064:random number generator:SSLEAY_RAND_BYTES:pRNG not seeded (crypto.c:113)".
I found some stuff on a hungurian forum saying to enter
rm /dev/random
rm /dev/urandom
mknod -m 666 /dev/random c 1 8
mknod -m 666 /dev/urandom c 1 9 "
into ssh, which seems to help, but i really have no idea what's going on.
albertlee
rm /dev/random
rm /dev/urandom
Are you trying to compile Transmission yourself? Seem like you have issue with SSL libraries.
Installation is very straightforward, I even "modded" FFP to include Transmission and automate some initial setup tasks. Will put it somewhere if anyone interested to try out.
LX2010
I'm actually pretty new to ssh and the entire system. Tried installing transmission through googling and the like so I don't really know what I'm doing actually. Tried to install sane to get my hp all-in-one printer working but that sorta turned out as a disaster too.
Would be great if you could post your modded FFP somewhere with some simple instructions :)
albertlee
Okay, will need to "refresh" it will the latest libraries release before posting it, probably on mediafire site. Instruction will be simple, just need to run 1-2 script and you're good to go.
