Need Help
gab123
my desktop of one year giving me problem. surfing HWZ wif 5 tabs, internet explorer will lag. cant view 1080p movie, will lag after view mins. 720p no problem.
using win 7 ultimate
Intel(R) Pentium(R) D CPU 3.4GHz
8gb ram
64 bit operating system
Display adapters Intel(R) G41 express chipset
Windows Experience Index rating 3.5
can anyone give me suggestion on how to solve tis problems
royfrosty
Can really overhaul already.
Intel(R) Pentium(R) D CPU 3.4GHz You sure is one year old? In intel database this is already more than 7 years going 8 years.
gab123
ya I got it last year after my xp desktop died on me. tat means tat asshole cheated me liao
gab123
i requested for I3 or I5 but he say i only use it for normal web surfing n movies, tis is enough and i paid 700 in all for 8gb ram, win 7, and 1tb hardisk
Hailgod
I think he got that processor + motherboard off a 7 year old com and happily sell to u with profit of $500+. If he dick enough to give u a **** processor, quite sure your windows 7 also illegal one.
gab123
how do I check for windows see if is fake??
Hailgod
Did he give u the original windows disc? Also, even if is illegal it won't have any problem. Just saying that to show u how he cut cost and chop u hard. This pc probably took him lesser than $250 to make.
gab123
my previous set was 8 year old DIY from sim lim. I bring down to tat shop together wif my win XP cd tat time still have promo for upgrade to win 7 or 8.
so tis set is basically my old set wif new processor, ram and win 7
gab123
so tis set should b one year old cos I did it about before the promo ends
Hailgod
gab123
just call him, he say tat the windows purchased from Microsoft dunno wat thing, he just ask me bring down for him reformat it
gab123
check wif him regarding the lag and he told me due to using onboard graphic tats y I experience lag, n ask me purchase new dunno wat pci expresscard wif hdmi output from him
ykgoh
Sad to say you have been conned or at the very least chopped by your PC seller.
Suggest you approach Nigel and see if he has any better decent used CPU/mobo to help you upgrade for minimal costs (maybe $100-$150). I suspect your RAM also DDR2. At least your OS and RAM can reuse.
Else you can also easily get a much better machine new today for $3xx at SLS, I think with Intel Pentium Gxxxx processor. Or find Fortran to recommend you something.
Hailgod
If you want good help, go to GS aka Nigel's shop. Pc cares and solution #02-32 if i never remember wrongly. That guy trying to scam you more money. You are on a 8 year old cpu + motherboard that he supposingly upgraded for $700. All he did was install windows 7 + add more ram. Doesn't even cost him $200
Hailgod
If you still got the reciept/invoice of the upgrade he did, Can report to CASE
royfrosty
Really chop head. Please expose the shop and warn others about the shop.
