Need Help
gab123
ram is ddr3 8gb. I just bring down show him, open tis thread show him n after tat **** him upside down
Hailgod
ddr3? You sure ah? I didn't know lga 775 motherboards supported ddr3
LOL you want to fk him upside down in a church?
shadow84
What can you f**k him with??? Show him this thread also no point. Later he go smash your com, your $700 gone le.
tamjinhang
No use gg down I think. I can fix it super cheap with one core 2 quad and a decent gfx card. =p
ykgoh
Later he complain to :vijayadmin: then we all tio banned for defamation and smearing his business reputation.
But enjoy your piak piak. :evil: Don't be too rough on him. :s34:
ykgoh
Bro, teach you 2 more tricks.
Trick #1: You know your Windows 7 Ultimate comes with Snipping Tool to take screenshots?
Snipping Tool - Microsoft Windows
Trick #2: You know there's something called the
Code:
[IMG]
tag?
tamjinhang
Simple G41 / DDR3 mobo combo. At least using some decent Gskill value RAM (black ones I suppose?)
@Hailgod: Yes, it exists..... in the RAM timings programmed and allocated into the RAM itself. Look at JEDEC #1. And the reason why it only runs at 800MHz is simple: FSB. The FSB of the Pentium D is just 200MHz, Since FSB:DRAM ratio is 1:2, DRAM freq becomes 400MHz. Multiply by 2 again because it's Double Data Rate (DDR) RAM, resulting in value of 800MHz.
I'm sure the RAM can run at its default spec of 1333MHz if u increase the FSB to 333MHz. The problem is that Pentium D may not be able to run at that FSB speed; even if it can, the Pentium D chip will burn! At default settings, the Pentium D can bbq people already. One Acer desktop I encountered, based on Pentium D, actually had a 3-heatpipe CPU HSF installed! U know s&#* gets real when OEMs have no choice but to spend extra on CPU cooling...
I miss the days of playing with LGA775. Unlike the CPUs now, these guys can all essentially OC (using FSB). Who cares if it's a Pentium Dual-Core (NOT Pentium D), just up the FSB and overclock!
@gab123: The MSI G41 mobo can definitely handle any LGA775 CPU out there, so a super cheap choice / solution will be to get a proper Core 2 Duo/Quad CPU and a decent graphics card, as mentioned earlier. Faster and much colder CPU makes it an easy choice. I have also sent u a private msg; have a look too.
