Need Help
Hailgod
under my windows activation, it says windows is activated and wif product ID, is tat some sort of proof is genuine copy??
No. My macbook air says the same thing from my torrented windows 7 professional. Did he give you the official windows 7 disc?
gab123
he never gave me a disk. the past few times when my XP breakdown n he help repair, I saw him installing from a cd tat is not my XP disc, but during the product code part, as my copy was a old one, he call n get a new updated product code
Hailgod
So do u run windows 7 or XP? There's no way he will buy a windows 7 ultimate. Confirm is torrent one. If is real one most likely will be windows 7 home premium.
Hailgod
My expectations = Deny everything. Say never build before.
Also, the reason why windows 7 ultimate = fake one is because no one buys it. Its 2x the price of windows 7 home premium.
ykgoh
my desktop of one year giving me problem. surfing HWZ wif 5 tabs, internet explorer will lag. cant view 1080p movie, will lag after view mins. 720p no problem.
using win 7 ultimate
Intel(R) Pentium(R) D CPU 3.4GHz
8gb ram
64 bit operating system
Display adapters Intel(R) G41 express chipset
Windows Experience Index rating 3.5
can anyone give me suggestion on how to solve tis problems
TS, you've been scammed and it's not likely you can pursue the matter further to get any money back. Complaining to the shop is also useless and a waste of time.
I realise that the Pentium D and your mobo is using LGA775 socket. One way to minimize cost while improving your system is to look for a second hand Core 2 Duo / Core 2 Extreme / Core 2 Quad processor. I seem to see such processor available cheaply like $20-$30 every now and then in CPU, RAM & Mainboard Bazaar. It can be a very cheap but effective upgrade for your situation.
Example WTS thread (Core 2 duo E6750 @ $30): http://forums.hardwarezone.com.sg/c...re-2-duo-e6750-$30-pentium-d-$15-4514240.html.
Example WTS thread (Core 2 Duo E7400 @ $25): http://forums.hardwarezone.com.sg/c...ore-2-duo-e7400-lga775-processor-4483612.html
You can always search for better deals around.
Warning: I'm afraid if you upgrade and swap your processor, your Windows 7 Ultimate may detect a hardware change and demand a re-activation. So up to you whether you want to try this suggestion.
tamjinhang
I have a core 2 quad q8400, along with various graphics cards. Can sell u for dirt cheap! That should solve ur problems real good. The repair shack will gladly welcome u. :)
gab123
not sure wat my ram is ddr2 or 3, how to check without opening case?
as usual keep asking me buy parts to add on, I ask him about the processor thing he say due to my usage, he says tat is powerful enough. never go down just call him cos today busy. planning go down sunday after his church wif my pc
ykgoh
Use this: CPU-Z CPUID - System & hardware benchmark, monitoring, reporting
Select Memory tab. TADA!
You still want to return to Nicam? You kena his gong tau is it? :s22:
Anyway, up to you lah since it's your money and PC. But you know he hasn't been a honest seller all along.
Hailgod
Dont need to check. 8 years ago no such thing as ddr3.
