New PC builder here, need help.
zleipnir
Actually u won't be that sensitive to feel the difference unless u are watching the FPS metre as u play games lol...
These videos are doing quantitative analysis mah else mouth talk not convincing.
so what I got from the video linked is that it's not really worth getting the 3600mhz ram?
clay9477
Yes, as mentioned really no difference unless both are the same price else it isn't worth shelling out the $ for it.
The $ can be put to better use like buying the next tier of GPU(Graphics Card).
FreSch
well, as long as it's over 60 at all times I'm happy lol
clay9477
One more thing, do get Win 10 Pro instead, can configure Win 10 updates to defer to a year. Can defer 365 for normal updates, 30 days for exceptional updates that affect security.
Win 10 Home constantly filled with pushed updates, imagine shutting down PC but it goes to updating, you can't defer with Win 10 Home :s13:
Can visit TechYesCity youtube channel, got recommendation at exceptional value.
Kunkka
Den can get 3000 mhz CL 15 ram since its cheaper.
Posted from PCWX using LYA-L29
FreSch
i never use windows home, last time I touched that product was many years back, no worries lol
FreSch
Is the price that big a difference? because from what I can find in the pricelists, the price difference between the 3070 and 3080 is around 400 bucks or so
clay9477
I think you mixed up. 3070 and 3080 are graphics card.
3000mhz CL15 is Desktop Ram. 3000mhz CL15 can be overclocked to 3200mhz CL16 but it depends on manufacturer, no guarantees.
Buying 3200mhz CL16 is for ease of mind, slot in and on XMP, settled, don't need to go and tinker with all the values, memtest86 etc.
FreSch
whoops, quoted the wrong post. I meant to quote this one:
I was wondering if the savings from getting slower RAM would even be enough to upgrade to a higher GPU.
The difference in RAM price doesn't even come close to the GPU difference, so that's why I was a little confused.
Also, no, I don't believe in overclocking, and I'm not planning to do that for a long time, if at all.
FreSch
https://pcpartpicker.com/list/x4ZQwz
I believe this is the final build. All prices manually input in SGD.
I'm a bit worried about updating the BIOS to support the 5600X though, the shop will help me update it, right? or only if I let them build it for me?
zleipnir
If you buying the mobo from them, ask them for the one already flashed. I bought my ROG X570i from PC Themes already flashed.
Yongkit
https://pcpartpicker.com/list/2GGby4
I've changed my shop from allstars to PC themes.
When I asked somewhere else for a second opinion, I was told my 650W might not be sufficient for the 3070?
It depends on your setup below is guidelines:
Intel i5 & AMD Ryzen5
RTX 3090 - 750W
RTX 3080 - 750W
RTX 3070 - 650W
Intel i7 & AMD Ryzen7
RTX 3090 - 750W
RTX 3080 - 750W
RTX 3070 - 650W
Intel i9 & AMD Ryzen9
RTX 3090 - 850W
RTX 3080 - 850W
RTX 3070 - 750W
Intel HEDT & AMD ThreadRipper
RTX 3090 - 1000W
RTX 3080 - 850W
RTX 3070 - 850W
Try the wattage calculator below:
https://seasonic.com/wattage-calculator
footi3
Do you use optical drives? If not for your case, can consider coolermaster NR400 (without ODD) or if budget constraints.. tecware nexus / forge M
Posted from PCWX using SM-G985F
FreSch
RTX 3090 - 750W
RTX 3080 - 750W
RTX 3070 - 650W
RTX 3090 - 750W
RTX 3080 - 750W
RTX 3070 - 650W
RTX 3090 - 850W
RTX 3080 - 850W
RTX 3070 - 750W
RTX 3090 - 1000W
RTX 3080 - 850W
RTX 3070 - 850W
According to what you just sent, 650W is recommended, so I'm good then, thanks.
No, I don't use optical drives. The case Is the cheapest I could find, I don't care for looks. If there is a cheaper option, I'll take it lol (I know many people will kill me for taking an ugly case but eh, I don't look at my pc all the time anyways)
ItsmeagainhK
Get higher wattage psu la. 750 or 850 since there is budget for it.
