Normal GTX 780?
memoriess
I asked tradepac already. They quoted $725 if I wait for them to restock which will be next month.
Didn't wanna wait so I hooted @ $730. Close enough. :s12:
MNC has good prices for ram sticks though. Without bargaining that is.
So if you wanna buy ram, lazy to bargain and travel to sls, MNC can do delivery at pretty competitive prices.
MNC? May I have the link to the shop?
shadow84
Bros, I ask you all. What do you all think of EVGA? Does it come with backplate?
Evga not bad, cooler is efficient. Does not come with backplate. Can be purchased from amazon or see if convergeant can help bring in for u.
Yureak
EVGA must buy your own backplate. Its good for overclocking but save your time and money if you dont oc
memoriess
Don't talk about price wise, but about performance and quality. ASUS Dc2 vs EVGA SC with acx cooler. Which one will you all go for?
memoriess
Hahah. You 2 making me confused, so if I buy backplate myself. Any shop in sls selling?
shadow84
Read the reviews and make ur own decision. Can read from techpowerup. They compiled from a few reviewers.
All evga gpu dun come with backplate, need buy seperately. Can get from amazon as it qualifies for fssg,jus need to meet min us$125.
Otherwise, try ask convergeant to indent one for u.
Yureak
For a touch and go user like him best to use a simple solution just slot in and forget about it. In that i think the dc2 excels.
I have an ACX cooler opened it doesnt look very good inside too
shadow84
It is good that he reads the reviews and ownself decide, instead of jus following a fanboy's decision.
And for touch n go user, it does not mean only Asus fits the bill. All brands can fit the bill. He needs to know what are each brands' pros n cons.
To TS, i suggest u read up. Yureak is a well known Asus fanboy. You can choose to follow his advice, that is ur decision. But dun ditch other brands jus coz of his words.
memoriess
Definitely I will make my own decision. I will probably take some times to read up the reviews. But one question, are those cards on stock speed or overclocked speed?
shadow84
Some are using stock 780 clockd as the base clock. Some have boosted their base clocks higher.
Yureak
I am an EVGA Classy 780 owner and the card i owned before this was an Asus 780 dc2 and before this a Palit 780 Jetstream. Therefore from my personal experience having owned 3 780s i am sharing on the difference between brands.
If maybe you switched over to green camp and have owned several units of GK110s you'd be in a better position to see the difference and provide advice. If all your knowledge is gleaned not first hand but merely on reviews then i would say that is a very shallow view.
Dismissing me as a fanboy doesnt lend any credibility to you at all. I am sharing in all honesty.
EVGA is good for excellent customer support in the US but locally it is no different since we go through distros.
For build quality wise Asus DC2 still comes out on top over EVGA even for high end Classified models.
This is simply from my personal observation. Unless you are going to do extreme overclocking id stick with the safe option. At the end of the day you can check reviews its still a 780 and the performance is roughly similar.
What is different is how the item feels and is built. I dont get money for promoting a certain brand or unit
If youre overclocking heavily to match 780 Tis without overvolting
Go for Gigabyte Ghz Edition or MSI Lightning.
If you are running custom water cooling and want to overvolt and overclock to smash even overclocked 780 Tis get an EVGA Classified.
If you want a simple hands off solution and just have a unit ready to pull punches on any given game today just get a 780 dc2
c0ke123
What happened to all the MSI 780 lightning. Seems like nobody is selling already. Was thinking of getting a 2nd card for myself to SLI(if the the price is right) then upgrade to a 1440p monitor e.g., ROG Swift. And I'm sure the price will be way cheaper compared to when it was first released.
Yureak
Not very popular i guess...
Supposed to be a premium model but i think it priced itself out and it doesnt oc as well as its competitors beyond 1300mhz
allhomme
Actually in the "I want performance and screw the looks" category, I would recommend MSI TF. Performs roughly the same as DCII but lower price. It's those install and forget cards.
If you're one of those siao lang(aka me), get something from the EVGA Dual Classifieds. at least it has a backup VBIOS in case you botch the BIOS mod.
