Note 2 battery life
carey
My batt also drained 20+% while i was sleeping last night.
I checked and it showed that my phone was 'awake' when my screen was off.
How do i check what apps are running in the background and draining the batt?
That's the hard part - a lot of trial and error needed...hahah
Usual suspects include auto-sync of accounts - FB, Twitter etc
Fortunately, you can use System Panel - it does a good job of showing all the apps plus running processes and how much CPU time each of them took up...
You can use that to narrow down the list and then decide if you really need those apps :s13:
Some of the "free" apps are notorious for eating up bandwidth by constantly pushing ads to your phone even when the screen is off...
So you may want to consider blockers like Droidwall etc to restrict access...
I posted a guide a while back - it's very helpful and I certainly benefited greatly from it...hahah
salemfalls
THanks thanks.
Strangely it only seemed to happen after i updated the software. I am on LJ3right now. Didnt have this issue when i was on LJ1. Sigh.
My autosync is turned off, so that shouldn't be the case.
Looks like i will have to try system panel and monitor again tonight.
Can i have the link to your guide? TIA!
V
victorlht88
Guest
This is an interesting issue and reported in xda too. Anyone noticed a buzzing sound from your ac adapter when charging?
Ruriel
Yup, mine did. Someone mentioned it here before... and also got people mention in XDA... but apart from the buzzing sound, everything else seems fine, so I just make sure I off the power and take the charger off the socket every time I'm done using it...
jeme1981
Need help
71%
8h 53mins on batt
Screen 73% time on 1hr 14 mins
Device idle 13%
Cell standby 12%
Android system 3%
Wifi 2%
Is my batt draining abnormally?
I Dun have 4g service so I shd choose gsm/wcdma (auto mode)?
carey
Need help
71%
8h 53mins on batt
Device idle 13%
Cell standby 12%
Android system 3%
Wifi 2%
Why abnormally?
29% over nearly 9 hours = 3.2% per hour and your screen time is over an hour woah...
It's already quite good :s8:
kimurastanley
Need help
71%
8h 53mins on batt
Device idle 13%
Cell standby 12%
Android system 3%
Wifi 2%
Pretty normal for me
carey
Thanks
Cos I saw my network keep jumping fr G H H+
Same here but don't think it affects the phone much unless i am moving...
Then the drain is quite bad - suspect it's more to do with the scrappy network than the phone :s8:
jeme1981
Jus now I went out den it keep switching between G H H+ my batt drain 12% within 50 mins thats y I feel is abnormal
siandiao
Moderator
Moderator
mine is worse, drain becoz 4g-H+-4g widly becoz Starhub hasn't implemented 4g fully at NUS side yet
shidenx
i use battery saving app to limit the data network can last super long.
12hr day with minimal usage maybe only 20% drop only.
carey
In instances such as this, I usually just switch to GSM only
carey
Or just off all data until you need to use it
Confirm will last super long too :s13:
shidenx
airplane mode :crazy:
aiya the app does it automatically for me no need to go into settings back and forth.
