Note 2 battery life
OkPhoner
This is the day SMS, surf the web, download applications, play a new game.Good things, I do not worry about the battery life of cell phone accessories store purchase 2200mAh multi-functional Extended Emergency Battery pool amazing
ameelia
My battery only last a day. 2nd day after I bought it and charging full, here's the stats.
17% discharging - 17hrs 52min on battery.
Screen- 46%
Android OS- 14%
Android system-6%
The rest relatively low.only use whatsapp, some surfing and phototaking.
Tdy, with some video watching,
26%- Discharging - 10hrs 51min on battery
Screen- 42%
QVod -19%
Android OS- 7%
Rest also quite low.
Is this normal??
Cant post image yet. Hehehe
carey
Wow! That seems really good.
Are you on stock ROM? For the "Screen" part .... how many minutes is that?
Rooted but still on stock ROM
This morning - 96% after 6.5 hours with 21 minutes of screen time
carey
Screen- 46%
Android OS- 14%
Android system-6%
Screen- 42%
QVod -19%
Android OS- 7%
Is this normal??
Click on the battery graph and check your "awake" line...
Is your phone awake for long periods of time even when the screen is off?
If yes, then some apps are still using up computing power and battery in the background...
justln
Wah! Why ah? You got do any settings? I didn't root/flash new firmware. But drop 20% overnight leh.
Some app is keeping your phone awake. My note 2 drops over 40% overnight but that's because I have a sleeping app that keeps track of my deep sleep.
carey
I already posted a guide on how to optimize battery life for S3 - it works for Note 2 as well
Remove auto sync for non-essential apps and stop random apps from constant access to the net (biggest drain of battery when your phone is supposed to be asleep)...hahah
A quick trick - look at your data icon - is it constantly flashing even though you are not running any app?
If yes, then you should find ways to stop or restrict their access...
b0ib0ii
I removed auto sync liao leh. Still drop 20% can share the link pls?
gibson7
for me...never.
i buy liao straight away pop in sim card, battery and start using.
battery took a couple of days to reach max potential.
