Note 2 battery life
hero001
This one??
Standard battery, Li-Ion 1230 mAh
Well note 2 is on 3100 mAh so you can't really complain can you? The battery capacity of note 2 is more than 2 times your old phone so it will naturally take longer to charge ma. With usb some more.
es0teric
Lol, no leh. I am not saying that why it take longer to charge. When my phone batt was at 78%, I insert the USB cable. An hour later, it become 75% and follow by 74%. It was not increasing at all.
Skyy
maybe if you never insert the usb cable, an hour later it would have dropped even more, an hour later could be 70% instead of 75%
es0teric
If that the case, which external battery charger I should buy for note II?
justln
So cheap? Think those batteries can't last very long one..
I tested them out with 1 hour video max brightness and sound, airplane mode.
Original left 85%, third part 75%.
For $15 per battery compared to original $50+, I think it's damn worth it. :s12:
justln
Put inside Note 2.
Settings > Storage > Format SD Card.
ChaoAhGua
Oh..
I see people say ebay got people selling $5 per battery :s8:
That kind sure cannot last long :(
justln
Oh..
Got la, I got chopped carrot head. Some people posted they bought 2 battery + charger for $15.
Only for emergency use lo, still worth it. :s12:
SuperDecker
I used anker batteries when i was using S2, highly recommended. Anker has released the batteries for Note 2, can check out the reviews for it
