Note 2 battery life
hammerhammer
maybe if you never insert the usb cable, an hour later it would have dropped even more, an hour later could be 70% instead of 75%
If use USB charging I combine 2 USB ports to charge the phone ok but a bit slow. Use those external HDD casing cable with 2 USB connectors and plug into 2 USB ports to get 1A current to charge the phone.
i1magic
I am looking for external wall charger with output 2A to charge the Note 2 battery. I use the cheap ones which I got from eBay to charge the Note 2 original battery ... took almost 12hrs to fully charge the battery from about 1-2% to 100%.
Ratix0
Just something I've read, beware of cheap third party chargers. They can spoil your phone, cause fires etc.
Chargers actually have a great deal of science and engineering behind them and cheap chargers often do not have all the key safety design that comes with it. Voltage spikes, fluctuations and all sorts of things that come with cheap third party chargers are actually quite dangerous to your devices. Read more here:
Ken Shirriff's blog: A dozen USB chargers in the lab: Apple is very good, but not quite the best
SLstweeter
4200mAh Spare Battery For Note 2
There's no mention of dimension for this High-Capacity GOLD Battery for Note II, but it looks like it fits the Note II without adding bulk
4200mAh, can consider?
source : OBOStore 4200mah Gold Spare For Samsung Galaxy Note 2 Battery
:s12::s12::s12:
i1magic
kspace
I know Challenger is selling some branded third party external wall charger which can gives you 2A current. The cable has to be purchased separately, so both items add up to be around S$30.. if you can wait, you can go order online from Obostore. I bought mine at USD15 for the charger plus cable. Waited 2.5 weeks to reach. I believe it is authentic Samsung charger and usb cable for Note 2, it looks like Korean set. Tried for 1 week plus dy, same performance as the genuine Samsung charger that came with the phone! Highly recommended.
i1magic
If it can charge the batteries in less than 3hrs .. means same performance as stock charger liao.
Got link?
floxika
Wah ... help you repost ..
Really unbelieveable leh ... with 5hrs screen on ... can still last >2days!!
Thanks for the re-post..
i don't root my phone and just off the useless apps using system panel.
i also use cpu spy to monitor deep sleep.
normally from 10pm-7am, it will drop 1% to max 2%.
really strong battery..
and i am not expert to use kernel (or whatever function) to fake this.. wat for
phayze
Why not buy the ipad charger from apple for $28?
Do get the 12W instead of 10W. The apple 12W charger can output 2.4A, and most important there's no noise from the charger when charging.
