Note 3 Finally gets Lollipop
pilico
Hey guyz is there any alternative way for OTA update to work?
I tried to update from kk to lollipop but my phone says it is on the latest version.
goh6570
Am still waiting for more feedbacks.. as the lollipop verison just rolled out to note 3?
tkl23786
lxb_70
bobaccord
No lollipop for me so far
:s11:
My wife and I bought the Note 3 together during the launch month back in 2013.
Yesterday, her Note 3 upgraded to Lollipop seamlessly last night.
As for mine, each time I check the software update under 'about device', I always get the same reply - 'The latest updates have already been installed.'
Any other way I can do the upgrade?
Sigh....
Bob
barleywater<3
Ya my singtel set also no update to lollipop! Mine is rose gold set. All my note 3 friends upgraded already lah!
Anyone knows why?
tkl23786
Mine is bought from Singtel but I changed the code to XSP ages ago.
Maybe the traffic lights have not pushed out the Lollipop update???
Need more feedback from those who managed to upgrade about this...
Some-one
:s11:
Sigh....
Bob
Using Samsung kies is another way.
sunht
After upgrade to lollipop, my lock screen doesn't have new message/whatsapp, etc icon if there are e.g new message / whatsapp comes in,after unlock then I can see the icon on the left top corner.
Now also can't recall if kikkat has it or not.
tkl23786
After upgrade to lollipop, my lock screen will not have new message icon if there are e.g new message comes in,after unlock then I can see the icon on the left top corner.
Using the default messaging app?
Launch the default messaging app
Tap on the left capacitative "button" next to the Home button and select Settings
Tap on Notifications
Check the Preview message option
There you go...
:D:D:D
Cheers!
newcell
Those cannot, dont give up.
Restore to orginal/factory reset and try again Kie3.
newcell
2nd day after upgrade, no major issue so far.
Bluetooth needed re-pairing, otherwise perfect.
No changed to cam app, but happy with slight speed improvement.
Always running system ram below 2GB.
