Note 3 Finally gets Lollipop
bobaccord
Guys did ur encounter went take photo there is no sound after i updated my note 3 to lolipop and any solution
Hi,
Sound is still there but check whether you mute your phone. There will be no click sound if you mute your phone.
Stealer
I had updated mine last sunday.
Now my whatsapp cannot be connected unless Im on home wifi.
Last nite, I used google map as GPS.. it looses connection and I had to get my wife note4 to do it..
It seem that this upgrade is causing a issue for note3.. anyway to downgrade?
lxb_70
did u hard reset? maybe that will help...
Whizdom
guys stupid noob question. how to flash new lollipop firmware?
i tried by using the phone no updates no nothing leh
Stealer
found my problem.. had somehow set my APN to "prepaid" instead of "Postpaid".
Now I can connect to internet..
'whatsapp' can be sent now when I am outside my home.
lisazhang
My initial observation after using Lollipop on my Note 3 for a week or so...
My wifi keeps losing connection once a while. This does not happened under Kit Kat. But it is not a major problem for me.
Bob
I am having the same issue.
ralph79
Same goes with the Bluetooth. Kept losing connections with my smartwatch.
newcell
So far after upgraded, about 2 weeks.
All working fine. Wifi (Asus N56U) both band experienced no drop, as stable as KK.
Only grunt I have is bluetooth auto connect not as smooth as with KK.
Connecting to my Jabra handfree unit was perfect but not with my Pioneer set. Factory reset pending.
* Pioneer set Bluetooth driver updated, working fine now.
bobaccord
bluetooth and wifi
I also discovered that if I use my bluetooth headset, the wifi seems to disconnect itself on its own. So, finally out of frustration, I revert back to my wired headset, and it improved. However, especially in the evening, the wifi tends to disconnect itself & back again after a while.
Definitely some lollipop bugs.
Bob
bobaccord
Hi
With the lollipop upgrade on my Note 3, I discovered this feature where a writing pad is opened when the S-pen hovers near the screen is missing (e.g. writing sms). That is a very useful feature if I prefer to write my text rather than type.
I tried to find it but failed.
Anyone can show me? Or has it been removed withe lollipop upgrade?
Thanks
Bob
ATN888
hover spen over text input area, handwrite icon pop up, tap on it.
