Nvidia RTX5000 up to +30% better than RTX4000 (only!)
final1
kappak
rtx 5080 cost $3000 coming when trump hit china with 20% tariff
Sound like you have 5080 on hand wanna sell 3k.haha.
Sg Local price jack up high coz have china buyer come in buy.
Now china itself didnt sell 5080 for 3k also.
Only 5090 can fetch higher coz china dont have this model.
fkchon
aight maybe sim lim aint that bad
I managed to pick up a 5080 for a really reasonable price today
shidenx
no rush just wait till things settle down.
nvidia just made a good segment of people turned off to be honest.
stay on old gpu till prices become reasonable...
justln
zotac cards.... abit ugly sorry lol
Lol I don't even want RGB inside my case, all turn off so ugly GPU or not, doesn't matter. :s13:
Anyway, 5080 with MH Wilds, 4k stutter like crazy and fps fluctuates up/down/left/right, had to go to 1440p to brute force performance.
Edit: is the highest texture causing stuttering cause it renders everything your camera see, all the way into the abyss.
Changed back to high texture, 4k, still ok.
Phen8210
NewEgg just listed 5070 $850 SGD doesn't seem too bad but then compared to AMD it does seem very expensive for what it is
https://www.newegg.com/global/sg-en...geforce-rtx-5070-12gb-gddr7/p/N82E16814126761
The key question is whether the RTX 5070 using DLSS 4 transformer based upscaling in Quality mode will outperform a similarly priced AMD GPU running at native resolution.
This is due to the Nvidia card already having better image quality when using transformer model. Also, due to lower internal res when using upscaling, there will be performance gains. Furthermore, It is very easy to enable it for games that already has DLSS support.
Previously, updating DLSS DLLs required manually replacing the files in the game directory, or using the DLSSTweaks wrapper, or configuring settings through NVIDIA Inspector.
Now, NVIDIA has streamlined the process with the NVIDIA App, allowing users to enable the transformer model for any game that supports DLSS.
Yesterday, I enabled the transformer model for Monster Hunter Wilds, all it took was selecting Preset K in the NVIDIA App.
Meanwhile, AMD's FSR 4 is at best comparable to DLSS 3 but suffers from poor adoption. Some games don’t even support the current FSR 3.1, leaving players with either native 1440p native which will have very noticeable aliasing, or with TAA that will reduce visual quality to something closer to 1080p. Plus, NV sponsored title like the ones I'm playing don't even have FSR in it at all.
alauz
That's the SKU AMD's targeted squarely in their sights. But the 9070 at $549... if both 5070 and 9070 sell at the same price, who will buy 9070?
ignies
Nobody will buy rtx 5070ti now since the 9070xt beats it
i doubt it, not in singapore at least.
local pricing likely cmi, I would guess 1k to 1.2k. if you value dlss, that addon 200+ dollar for the 5070ti might be worth it. fsr4 likely will only compete with dlss3 atm, and its less supported. if can get at 900sgd, I would say its worth, but otherwise it depends on what you want. nowadays games all optimized like dog (see mh wilds), will need upscaling one, cant even bruteforce performance.
fkchon
I don't think so.
RTX4080 and 7900XTX was similarly priced. Now all 4080s are out of stock and you can still get a brand new 7900XTX for $1300 local. People make their choices, AMD has to be faster and significantly cheaper for people to switch.
Phen8210
MH: Wilds performance is really bad, I refunded it. Usually with DLSS Quality (I used transformer model), I expect it to be hitting higher frame rate, but the FPS is too low.
When i saw people with RTX 5080 testing at 1440P in the outfields, i was shocked man.
Before anyone say to reduce quality setting, reducing it only increase fps by 10-15%..
Koenig168
Should have whacked a few RTX 5090s (and pay off the US national debt) in the 90 mins before Citi reversed the amount :LOL:
justln
Yeah really bad. I need framegen to reach 90-110 fps and the frame pacing is all over the place.
Need to wait for a few patches to fix performance.
https://www.play-asia.com/monster-hunter-wilds/13/70hu8v
$73.50 if you buy in the future.
