[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
Kiwi8
Deluxe Member
bro the problem is now not easy to get a device to rec via composite/component out
i wil prefer component out so i can get HD. Now SH all is HD already.
but build a HTPC to record isit too over?
A HTPC does offer more flexibility in offering the recording types u require.
harky
than u ppl get what brand , model of capture card?
kun1he2
To capture SH show only can use htpc?
Slightly OT since nothing to do with DVB-T2...
But anyway, I bought a 2nd hand AverMedia C281 to "copy" out all my SH Hubstation HD recordings via component cables.
terry1
selling this extra set of avermedia game capture that can record programs on miotv, starhub cable, etc in full-hd 1080p mp4 format. the recordings are broken into multiple 8GB files. leave your contact to deal at $360
harky
:eek: so ex?
kun1he2
Curious to know if you have tried recording miotv and starhub cable via the HDMI input?
FatalityV
Can you post a mediainfo of the mp4 files?
Just curious to see what kind of encoding settings they use.
harky
You can google. Think one shop in sls selling at that price but than not sure got stock a not. BTW how come record was in MP4? Not in Ts or tp?
may we know where can you get the set at $200++? thanks!
yes i am recording straight from hdmi and not from the other analogue connections :D
kun1he2
FatalityV
yes it is possible to be in TS format too
mediainfo with encoding settings, not this one haha.
It should look something like this
Code:
General
Unique ID : 175732508584318782878046141890010414306 (0x8434D99CC701014AAF889FE2570DFCE2)
Complete name :
Format : Matroska
Format version : Version 4 / Version 2
File size : 2.53 GiB
Duration : 48mn 45s
Overall bit rate : 7 424 Kbps
Movie name :
Encoded date : UTC 2014-06-30 10:52:24
Writing application : mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27
Writing library : libebml v1.3.0 + libmatroska v1.4.1
_STATISTICS_WRITING_APP : mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27
_STATISTICS_WRITING_DATE_UTC : 2014-06-30 10:52:24
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
DURATION : 00:48:45.389000000
NUMBER_OF_FRAMES : 87674
NUMBER_OF_BYTES : 2573408010
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 48mn 45s
Bit rate : 6 892 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.111
Stream size : 2.35 GiB (93%)
Writing library : x264 core 138 r2358 9e941d1
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-5 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=288 / keyint_min=27 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 48mn 45s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 134 MiB (5%)
Default : Yes
Forced : No
es0teric
Hi,
My PCI TV card is spoilt and need to get a replacement. Recently heard and see a lot of TV box posting but I am outdated.
My PCI TV card connect to the scv wall socket to receive signal from mediacorp, as for the replacement, does it still connect to the SCV wall socket or using antenna to receive signal?
Secondly, my sibling room do not have any TV wall socket and if were to watch TV channel on laptop, is there any device that can watch on laptop without a need of the tv wall socket? If using antenna, will the program have a lot of noise or will give a clear screen? Please help. TIA!
cybertech
Wonder anyone using this AVerTV Hybrid Volar T2 H831 (USB) selling at S$95 at SLS?
TBS5220 USB DVB-T2 after conversion with shipping cost also coming to about S$92.
batuchka
Best confirm if that AverTV is v 1.3.1 compliant and suitable for use in Singapore's implementation of DVB-T2 just to be 100% safe ;)
kkhrome
hi guys... got a DBV-T compliant usb stick lying around for other uses and wanted to try out tuning HDTV. Read up that the switchover to DVB-T2 started Dec 2013 but DVB-T should still be broadcasting for a few more years correct?
Just wanted to check.. because my tuner wasn't able to pick up a single thing on 538mhz. Wanted to test test on CNA. Antenna is about 1-2m away from the nearest window.
Am I doing something wrong or is DVB-T already completely obsolete now?
