[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
Kiwi8
Deluxe Member
hi guys... got a DBV-T compliant usb stick lying around for other uses and wanted to try out tuning HDTV. Read up that the switchover to DVB-T2 started Dec 2013 but DVB-T should still be broadcasting for a few more years correct?
Just wanted to check.. because my tuner wasn't able to pick up a single thing on 538mhz. Wanted to test test on CNA. Antenna is about 1-2m away from the nearest window.
Am I doing something wrong or is DVB-T already completely obsolete now?
Mediacorp DVB-T channels are now all on 610Mhz.
Some DVB-T2 channels are transmitted via 538Mhz but there is no DVB-T channel at that frequency.
cybertech
Can the TBS5220 USB DVB-T2 able to watch more than one TV channels?
Currently my AVerMedia A188 DVB-T card can watch CH 8 CH 5 and CNA
same time in different windows using DVBDream. About time to switch to
DVB-T2 and if this USB stick able to do that will be good.
Kiwi8
Deluxe Member
Yes but only if the channels are on the same frequency.
For example:
CNA, CHU, OKTO on 522Mhz
CH5_HD, SURIA_HD on 538Mhz
VASANTHAM_HD, CH8_HD on 554Mhz
Thus if u are recording CH8_HD, then u can only watch CH8_HD or VASANTHAM_HD with a stick that supports a single tuner.
Sambuca78
Anyone tried DVB-t2 on your Android? Something like Geniatech PT360
https://www.facebook.com/geniatechglobal/posts/684499378288187
cybertech
For example:
Wah why they don't put CH5 CH8 and CHU on same freq :s11:
CH8 + Vasantham :s22: CH5 + Suria :s22: CHU CNA OKTO still ok.
PoloBoiBoi
ChU CNA Okto all SD thats why can squeeze into 1 channel mah ...
the rest all HD only enough bandwidth to squeeze 2 into 1 channel mah
kkhrome
tried 610mhz and still nothing... ordered a coaxial to mcx connector so I can try tapping into the building-top antenna... maybe my room reception is just really bad.
LxIxVxE
Senior Mentor
Hi LIVE
Which software would you recommend for live tv?
I tried dvbdream etc but the software is very unstable. The only stable software that i have that supports DVB T2 is NPVR. I prefer standalone software (ie not those server/client type)
me using dvbdream, progdvb, smartdvb, dvbviewer and tbsviewer for testing and viewing
will post screenshots in next few posts
all tested with TBS T2 tuners and Win7 x64
LxIxVxE
Senior Mentor
DVB Dream (TBS oem version)
* crippled version with single recording only
* PIP and multi records only available in full retail version
01DVBDREAM_zps3a018ed3.jpg~original
LxIxVxE
Senior Mentor
SmartDVB (freeware with many functions)
* with PIP and EPG, scheduler and manual records
* channels scan - will inform u of new channels, updated channels or lost channels since last scan, good for finding what's new in DVB-C with hundreds of channels
* change default audio track for ur channels if u have stuttering audio with AAC 5.1
* others for u to find out urself
03SMARTDVB_zpsd96ec896.jpg~original
LxIxVxE
Senior Mentor
TBS Viewer (for TBS tuners only)
* simple software with basic functions only - watch, record, scheduler, pip, etc
* key in freq 522000 and end freq 610000, then scan range if unable to find channels using complete scan
05TBSVIEWER_zpsa01eeec9.jpg~original
LxIxVxE
Senior Mentor
Wonder anyone using this AVerTV Hybrid Volar T2 H831 (USB) selling at S$95 at SLS?
TBS5220 USB DVB-T2 after conversion with shipping cost also coming to about S$92.
please note that current AverTV T2 products does not work with Singapore T2, so dun buy
