testing something with lesser known software SichboPVR
last weekend
today updated to new version - Performance improvements
so far so good
juz got d TBS6285. but i cant seem to get it detect any channel.
tried connecting to d Cisco 4586 DVB boxset TV-out, SCV point and using d bundled antenna, no channel found. switched between d 2 drivers, DVBC & DVBT2 but still nothing. using TBSviewer & SmartDVB
hv switch back to my Hauppague WinTV-HVR2200
For DVB-C, use the driver 1.0.0.8 from their website:
http://www.tbsdtv.com/download/document/tbs6285/tbs6285-c-driver_v1.0.0.8.zip
I could not get DVB-C to work from the previous drivers too.
As for DVBT2, I'm not sure. Have u checked that your card has "DVB-T2 lite" sticker on it? If not it may be the older version that does not support DVB-T2 lite, which is needed to receive Singapore DVB-T2 channels. If it's the older card, do not worry, u can send the card back for them to send u the DVB-T2 lite one.
yes, already using either v1.0.0.8 for DVBC or v1.0.0.7 for DVBT2. there is no sticker found. any other method to differentiate between d 2 card version?
wabiang eh, like tat have to incur more cost siah! the cost & time...
When scanning for DVB-C channels from StarHub point using TBSViewer, select Cable instead of Terrestrial for reception type.
See this post for settings to use
http://forums.hardwarezone.com.sg/82021279-post296.html
Refer to this post for the frequency to scan for
http://forums.hardwarezone.com.sg/88135831-post2828.html
Using TBS5220 USB stick.
Hope this helps.
think i might have gotten a lemon? aware of the 2nd link u provide and hv tried all those frequencies. not aware of d 1st link though.
i retry d DVBC driver from scratch, and now im able to get stuttering audio and flashing/garbage video signal. HD5 was much better with lesser stuttering but HD8 was totally unwatchable
Hmm. Possible.
DVB-C channels from SH point are supposed to be stable, else you will have problems with cable.
Maybe you got an encrypted channel? When scanning, check "free to air" channels only.
I assume you can watch SCV channels from the same point?
maybe there is some DVBC settings i need to configure for TBSViewer or SmartDVB?
yes, it's d same cable for my Hauppauge card. right now is i toggle between the TBS & Hau card as i dun hv additional cable or splitter.
This is the old card:
This is the newer DVB-T2-lite-compliant card:
Why dun u connect first to your TBS and use the RF out from the TBS to connect to the Hauppauge card?
oh, it can be done this way? hahaha... me dunno wat d RF out for oso and so this is wat it's for. hehehe, me oni an IT guy, not electronics guy...
thanks kiwi8. need to find another cable though. sure will help unplug/plug the cable hassle from the back of the comp
Hi,
Can anyone recommend a CI-enabled PCIe card (like the TBS6991SE) that could be used with StarHub (i.e. we use the card from a "hired" set-top box)?
I am using this set up as well. Im using the TBS 6281 and hauppauge HVR4000. However i feel the RF out seems to degrade the signal as i seem to see more artifacts
Hello Guys,
I just move into my new home.. Sorry for a noob question..
I have a Sony TV that is DVB-T2...
I dun plan to subscribe to either ST or SH..
So i will need a tuner in order to get HD channels?
Cos i thought if the TV is DVB-T2 means can tune into HD channels already.
Thank you...![]()
