TV usb usually supply current only.
Unless your tv can detect and read usb memory stick.
Don't mislead please... USB TV tuners will never work in TV's USB ports.
Sorry about that. Was trying to say usb tv tuner not supported.Ya lor TV got no driver for the tuner
Most of the TVs can Read Memory cards for Pictures, songs and SOME Video formats.
Does anyone know where I can get the PCTV 292e (either locally or online)?
Can consider TBS5220 as an alternative. BuyDVB.net
Agree. A number of us using TBS5220.
Buy from TBS5220 USB DVB T2/T Freeview HD TV Stick-Watch DVB T2/Freeview HD TV on Laptop/PC [TBS5220] - US$39.19 : BuyDVB Online Store
Can this use for laptop? No TV access point
No need access point. It comes with a stock antenna.
However you probably need to seat near the window to use the antenna./
No true TV tuner (not referring to those internet TV types) works without antenna. U either have to use the StarHub antenna point, HDB antenna point, or external antenna.
My room don't have TV wall socket so I suppose have to use the antenna?
Also, during raining season the reception will be poor?
Can anyone tell me what is the minimum requirement for the laptop?
And lastly, most of you order from buydvbnet.com? Is it safe?
I believe its buydvb.net
Yes, they have excellent customer service quality afaik. I received mine delivered by dhl in like 3-4 days after it was shipped. Me and Kiwi just ordered another two tuner cards together because we wanted to take advantage of the discount when you buy in bulk!
raining season, my reception is okay okay bah, its just that sometimes for some reason my antenna will act up and there will be errors in my recordings...
Minimum requirement? streaming should be fine, but if you are recording, Im not sure if you require a slightly better specced laptop to avoid any errors in your captured stream due to the constant read/write on going.
I'm suspecting the 2 bundled antennas are crap, but all my tested antennas have coaxial connectors and will not fit on the MCX connector of the PT360.
I have the tv wall socket in another room. Do they provide a cable to link up to the tv wall socket?
Any cheap and decent dvb-t2 usb stick to recommend? I looked back the posts the price range from 40 usd onwards...![]()
that price is already quite reasonable I gues...
