[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
trueimage
Since the T230 is also supposed to support DVT-C, has anyone managed to get their T230 to work by connecting directly to the Starhub cable point? I tried it on my PC but upon scanning, all the channels were either locked or did not show anything. Am staying ard Tiong Bahru
P.S. Even when i used the supplied antenna, i only received locked channels!
Kiwi8
Deluxe Member
Wanna check with you all.
Has any of you bought TBS6285 Quad Tuner?
Mike_Lim
Bro, think T230 does not support DVB-C.
Under specifications from Geniatech T230 DVB-T2 Freeview USB Dongle
Fully Compliant with DVB-T2: EN302 755 (v1.1.1, v1.2.1, v1.3.1)
Fully Compliant with DVB-T: EN300 744
DVB-C should be EN 300 429
trueimage
Oh, i saw the following product description which mentioned support for dvb-c:
Aliexpress.com : Buy Geniatech MyGica Android 4.22 Enjoy TV Amlogic MX Dual Core TV Box Google tv 1080P XBMC media player mini PC TV box ATV520E from Reliable box shape suppliers on Geniatech Mygica Brand store
I think it DOES support dvb-c bec otherwise i would not have detected any channel at all when i only used the starhub point and did not use an external antenna.
FatalityV
thanks kiwi8! seem i got d new card as shown by your 2 pics.
im not sure whether SH is ready for HD8 as the video stuttering is simply cmi. however HD5 seem stable enuff though with occasional video glitches from time to time. im currently testing the different HD5 channel as shown.
and oya, im testing at bishan area.
Wall antenna?
Mike_Lim
Hmm.. you may have to check your software scanning configuration.
e.g. for the TBS stick, have to change "reception type" from "Terrestrial" to "Cable". Then there is "symbolrates" to set also.
See http://forums.hardwarezone.com.sg/82021279-post296.html
rza29
anyone here using dvb in car?
recently mediacorp upgraded the channels to only HD. now cannot view anymore channels once they went HD.
anyone encounter this before? previously digital still viewable.
Mike_Lim
Not using.
Is your digital DVB-T Or DVB-T2?
T is the old standard and has 3 SD channels + HD5.
T2 is the new standard and has all the channels with SD and HD.
Understand MediaCorp will eventually stop DVB-T , and make all DVB-T2 channels HD. Can check their website for details.
Sambuca78
Not using.
Actually what is DVB-C?
harky
i waiting for good device to rec via HDD na..
dont want to get a capture card :(
FatalityV
sian, I think my usb card tuner died...
keep cannot detect by my pc, also keep unable to view ch8 but can view ch5
