[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
LxIxVxE
Senior Mentor
Geniatech X9330 PCI Express Quad DVB-T2 TV Card
http://www.geniatech.com/pa/X9330.asp
LxIxVxE
Senior Mentor
Hey anyone which settings should I use for Video Recording Storage settings? Using High quality now, but I saw there are, Standard Play, Extended Play, and Long Play.
Anyone can tell me which is the best or what is the difference between them? Thanks! :D
those settings for analog channel recording only
selecting any of them won't affect ur digital channel recording since it does not make use of them
when recording digital channel, it will just write the transport stream to ur storage, untouched, no encoding needed
Sambuca78
bro, i've gotten the PT360 working on my pc win8.1 (using microusb-usb convertor) with T230 driver, TV IR and TotalMedia 3.5.
Able to scanned 8 channels, is that the default? (been ages since i watched local tv lol)
And also, anyone with the PT360, is it normal for it to be really hot when in use? :s22:
Wow! I only managed to get it running recently when I ran my T100 in Android mode. Still no luck in Windows even in windows 10. :(
Possible to share the version of the 3 application you used? Thanks.
acidcrash
Got any pic or link of the microusb-usb converter?
Looking to get the pt360 to use with both Windows and android. Thanks
adv_illusioned
anyone in the east(bedok) facing weak signal?
i used to have no issues until 2 weeks ago.
my 1 hour recording often has errors appearing around 10~20mins.
lGtayl
ok im back again,
Now my TBS 5281 tv tunner can receive t2 signals after they change a suitable chipset for Singapore for me.
Now the problem is, all the channels except channel 5 no sound ! (Images only)
Not sure what happen.
Using SichboPVR.
Anyone know how to fix this ? Also downloaded lav filters but no use eh
batuchka
Today went SLS walk walk saw Avermedia PCI-e DVB-T2/C tuner @ $99! Anyone hooted this and can confirm is DVB-T2 v 1.3.1 and fit for use in Singapore?
PoloBoiBoi
ok im back again,
Using SichboPVR.
switch to another sound track?
lGtayl
it doesn't have the option for me to select the track. Unlike hd5. I can see the aac logo below in their user interface
LxIxVxE
Senior Mentor
some softwares just dun like certain audio even when codec is installed properly
use other software lor
smartdvb for watching and simple recording
nextpvr for watching and multi background recording
lGtayl
sian, when I using cable connection, everything was perfect =(
I tried nextpvr, it gave me error what folder not found, cannot start live streaming
LxIxVxE
Senior Mentor
maybe u didn't set the correct live tv buffer folder in misc setting :s11:
just right click in nextpvr and check through all the settings
if u can use back DVB-C, best lor since they are using codecs which is more widely supported
if no DVB-C driver for ur new chipset, maybe can ask TBS abt it
Kiwi8
Deluxe Member
TBS5281 has DVB-C drivers. :o
LxIxVxE
Senior Mentor
me noe
just not sure what is his reason for not using DVB-C now for his updated 5281
last time ur old 6285 can use DVB-C but ur updated 6285 cannot use DVB-C until they released a new driver mah
Kiwi8
Deluxe Member
me noe
Dun mention my tbs 6285. I one full stomach of fire. My card has overheating problem of failing a while when recording 3 or more tuners out of the 4. Tbs refused to exchange for me.
albertlee
Beside TBS, is there something similar to Mygica T230 to recommend? Of course, pricing must not vary too much.
LxIxVxE
Senior Mentor
u always need to rma ur TBS cards
6280 => 6281
V1.2.1 6285 => V1.3.1 6285
now V.1.3.1 6285 => maybe they think u wanna chut pattern to exchange for the latest 6205 since the 6285 already EOL quite some times
ur 6285 also quite old, out of warranty? :s11:
last time no overheating problem, now got overheating problem?
