[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
mrsun18
Of course that's not what I meant but at the very least they should honour their warranty.
What is the use of a card that only works for a few hours when all 4 tuners are in use at the same time? :s22:
the seller said bo pai ma. How to settle?
I think sooner or later the card will be cooked. If you can't wait for that to happen, maybe you can think of a way to cook it faster...then it's really pai, no more argument :s13:
congster2
my mediacorp digital signal today is truncated at both sides for all channels. are you guys facing the same issue?
mrsun18
Do you mean pics? No problem with my Draco stb for both HD and SD channels (including those on T1).
For my Philips 32" with T2 tuner, no problem with HD channels too. U always display 4:3 although default was auto, have to do manual 16:9. The other SD channels on t1 display 4:3. No sure whether it was the same before as I never watch programmes on T1.
Maybe somehow your screen display format changed to 4:3?
soulblader_86
my TV has built in DVB T-2 tuner
by right I just connect the TV directly to the wall then scan okay le right?
my wall socket is the one I used for the past 10 years for analog signal one
is it wrong? do I need to buy anything?
please advise
batuchka
I have triple tuners in my HTPC
#1 Hauppauge 292E : All DVB-T2 channels today ok
#2 Hauppauge HVR 3000 : All DVB-T + Analog channels ok today
#3 Geniatech T230 : All DVB-C channels ok today :D
Kiwi8
Deluxe Member
Idea there.... looks like I got to make it spoil faster eh? :s22:
PoloBoiBoi
please advise
u need to connect it to an antenna and stick it out of your window
the wall one might be starhub cable de
albertlee
u mean like getting dvb-t2 channels from starhub cable?
chiu ask starhub if can allow dvb-t2 signals to be in their cable loh :(
Can work leh, me using this source for my T230, other then HD-5 the rest can receive.
mrsun18
You are mistaken. Your tuner receives DVB-C signal from Starhub, if plugged into the SCV wall point. DVB-T2 is the standard for terrestrial broadcast. DVB-C is the standard used by Starhub for cable transmission.
albertlee
That I understand, the thing is if I select "Cable" under Tuner Type it doesn't work, must select "Terrestrial" in DVB Viewer Pro.
Anyway, it doesn't matter as long as it for me. Also why discuss about TV set tuning when this thread is not all about them?
mrsun18
There was a problem of communication when you said "Can work leh" in response to PoloBoiBoi's post. I took it to mean that you could receive dvb-t2 from SCV point.
One difficulty I can see is that these tuners meant for pc are not certified to sg standards, particularly DVB-T2. Claims are claims. Until they are verified or certified, then we can be assured of compatibility. Same goes for DVB-C tuners. Some TV sets and tuners for pc that claim DVB-C capabilities also prove to be unable to receive Starhub channels.
I don't think the line is so thin. After all, the other thread is also about tuning, reception and related issues.
sunsetbay
Moderator
Moderator
DVB-C users, some free channels for u~ scan 370, 450 & 690Mhz~!
got Nat Geo, Discovery World, Food Network, Fox Movies Premium, NBA TV, HBO, HBO Hits, All Sports Networks~ all in HD~! :s22:
PoloBoiBoi
Fwah ... Who so ho xim at starhub, didn't turn on encryption for those channels
Or isit another those free preview promotion?
hummer
Got a cheap DVB-T2 box from Qoo10, all HD channels able to receive in Punggol even though not ready until 2016.
