[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
LxIxVxE
Senior Mentor
For portability on-the-go use what small-size, external and powerful antenna would you recommend to be compatible with the WinTV-dualHD dual TV tuner?
try with the bundled antenna first, maybe it is good enough for ur usage
haze_1986
Is the avermedia T2+C better compared to the HVR-930C-HD or PCTV 292e Triple HD? I have plans to plug the tuner into a computer that is always on and set up a tv-server for not more than 3 users. I was using a HVR-2210 for several years now for that use so would like to know which to upgrade to. On quite a tight budget so HVR-2215 is out for me. Budget of $100.
batuchka
i went to Cybermind recently ask the counter about DVB-T2 v 1.3.1 compliance of the Avermedia PCI-e tuner think the woman blur liao lol Anyone bought and confirmed current batches works with local DVB-T2 channels?
fireduke86
Avermedia T2+C, single tuner, $90 - $100
make sure u get the correct one cos last time sls flooded with old revision which does not work with local T2 channels, not sure the old revision still exist now or not
Hauppauge HVR2215, dual tuners, $189 - $200+
nothing much to choose locally
other brands or quad tuners need to buy from oversea
Thank you! :)
haze_1986
Thanks for the info. Actually if the Hauppauge USB tuners can achieve what I want I prefer the brand compared to averMedia. Is the avermedia the only one that can record one channel and watch the other?
batuchka
Avermedia i cannot say cos never worked with it and no bros input any short review on it also :s22:
i1magic
Item : MyGica DVB-T2 Receiver GeniaTech T230 DVB-T2/DVB-T USB TV Stick for Russia / Thailand / Singapore
Price : About SGD$29.50 (Limited time)
This image has been resized.Click to view original image
Source :
http://www.aliexpress.com/item/DVB-T...857742736.html
Ordered on 29 Jun 2015. Receive it on 13 Jul. Supposed to get it on 10 Jul 2015 but missed the delivery.
Tried it already. Can receive all the local HD channels + SD channels via :
1. Antenna supplied
2. Old TV antenna point on the wall
I managed to try out on the Starhub DVB-C TV antenna point. Scan and found 52 channels but cannot watch at all. CANNOT watch local channel at all.
Overall, still good buy.
I got this. It is pretty good.
And I managed to install Windows Media Center on Windows 10 using with this also.
Devilsire
Got any pic or link of the microusb-usb converter?
Looking to get the pt360 to use with both Windows and android. Thanks
I bought from carousell. Quite handy device to use for both pc / android
Sent from Xiaomi REDMI NOTE 2 using GAGT
batuchka
[QUESTION]
Owners of TBS and Avermedia DVB-T2/C tuners : is the remote provided programmable under a Windows based OS? By this i mean the remote has a sort of file one can edit to launch other programs besides the included PVR and/or WMCE? Examples wold be Kodi, NPVR, etc
Kiwi8
Deluxe Member
I have not really used the remote control feature of my TBS card.
But TBS cards supports WinLIRC to configure and receive remote control signals.
albertlee
Anyone try SichboPVR or ProgDVB? Both software crash (BSOD) on the T230 USB stick during scanning.
albertlee
windows 7 ultimate 64 bit and using it in DVB-C mode
OT a bit, I was wondering if SH will to continue to provide these FTA channel feeds once Mediacorp turn off FTA analogue probably by end next year.
batuchka
should be bah - digital switch over only mention complete phasing out of analog so dvb-c should not be affected
