[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
zoneguard
Happy to report Mygica T230 works when paired with Raspberry PI 2 running OpenELEC 6.0 out of the box. The tvheadend service and PVR client all run from the RPI but you need to enable OpenELEC unofficial addons repository to enable the PVR service.
I was setting it up for my dad using DVB-C. Tried DVB-T2 at first but his place isn't in the Mediacorp official indoor reception area yet and had some channels without sound - maybe it was the antenna. Gave up and switched to DVB-C off Starhub's and that worked without issue.
batuchka
Managed to get HD5 via DVB-C in OpenELEC?
liangtam
New Astrometa dongle that can do Analogue TV / DVB-T2 / FM Radio and AV in
Is cheapest US$30, more expensive than the Geniatech T230 but at least has working BDA drivers.
batuchka
Wow good to know bro - so what were your findings? Working with local FTA DVB-T2 in Windows 10 or not?
DARTHNERD
did anyone managed to get Indonesia or Malaysia Digital TV signals in Singapore?
if so, can post how to do it. Thanks!
Kiwi8
Deluxe Member
Hi didi, long time no see!. :o
Where can I buy this? So the AV also works ah?
albertlee
Me also interested to know more about the Astrometa TV stick.
Should be this one selling at USD29.61 with free shipping over at Aliexpress.
liangtam
Windows 10.
Astrometa TVR app on ntv7 analogue
Too bad I lost my Blaze HDTV v4 installer file which can do both, don't really like the TVR except you need it for FM and AV also.
Hi kiwi korkor
OT: Huai chiur new singtel classic plan cheaper than mine.
Kiwi8
Deluxe Member
Windows 10.
Hi kiwi korkor
So the AV cannot work using other BDA-compliant software like NextPVR ah?
On the SingTel Classic plan thingy, I really dunno wor. :o
liangtam
Also bought a Mstar7T01 based box for US$21.
The mini antenna is used for both earlier screenshots.
liangtam
Never try NextPVR.
The AV in audio think has some slight distortion though.
OT: CIS plan?
Kiwi8
Deluxe Member
Never try NextPVR.
OT: CIS plan?
Not CIS plan, just normal subscriber plan just that I had it for more than a decade liao. Anyway let's discuss this in the thread I created. :o
As for the AV, what about the Component (the three-cable video cable) AV capture USB device I found on AliExpress? Does that work better?
liangtam
Astrometa cannot do component in. There is an s-video option in TVR app but no cable provided.
So composite = 480/576i max.
Kiwi8
Deluxe Member
I meant this one:
Or alternatively, any HDMI capture card to recommend? Preferably something that has a passthru so that I can connect the output from the StarHub HDMI port to the card, then from the card to the TV. :o
zoneguard
Looks like there are 3 versions of Astrometa:
1. Version 1: http://blog.palosaari.fi/2013/10/naked-hardware-14-dvb-t2-usb-tv-stick.html
2. Version 2: http://blog.palosaari.fi/2014/09/naked-hardware-18-astrometa-amdvb-t2-v2.html
3. Yours is version 3.
BDA drivers: http://www.astrometa.com.tw/integrated_en.html
albertlee
liangtam
Nothing recommend. HDMI capture expensive
This one based on Conexant, but driver on CD is newer than Astrometa website. Maybe I should pry open mine.
