[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
Fatfool
i hv this~ tested on S3, lag on HD channels but SD channels are smooth~ most likely its the phone processor problem, though mygica PT360 advertise that it needs only dual core 1Ghz phone~
the bundle loop antenna is less usable, need strong signal area or outdoor to receive properly~ the other bundle bi-polar antenna is better~
anyway, this tuner drains the battery v fast and makes the phone hot, more than using 3G on youtube~ :s22:
Does it work for Android TV boxes?
PoloBoiBoi
Many models avail now:
Hauppauge WinTV SoloHD / Solo-HD Triple mode TV Tuner
Avermedia Mobile 510 for Android (EW510)
AVERMEDIA Hybrid Volar T2
Hauppauge 1975 DVB-T2 USB TV Tuner
all are local dvb-t2 compatible?
sunsetbay
Moderator
Moderator
dun hv android box, so not sure~ if u hv, are u able to install PadTV HD from apps store~? anyway, if u buy the mygica PT360 just to connect to android box, the cost is abt the same as u would buy a dvb-t2 STB~ might else just buy a standalone one~? :s22:
batuchka
These are sold locally. Looking forward to experienced users' review.
Err some of these sellers clueless about compatibility with SG DVB-T2 so confirm if v1.3.1 DVB-T2 compliant or even better if they got working demo in their shop...
Fatfool
That is possible but then the interface may not work with a remote control. I already have a standalone DVB-T2 STB which isn't any good. Everytime the wind blows, the image freezes. Already have a powered antenna. Wasz thinking of pairing this with a Nvidia Shield Android TV box
Kiwi8
Deluxe Member
Btw I was quoted $220 for the WinTV-quadHD. :o
I thought it was $20x but it turned out to be $2x0. :o
harky
Any way to receive a local channel with just a device and monitor in a room with only wireless?
Kiwi8
Deluxe Member
Wireless as in wifi? And that must be wifi with internet, otherwise it wun work. Then u can connect to apps like Toggle for live TV streaming lor.
harky
yes wifi.
a device connect to hdmi monitor can see liao..
what device can do tht ah...
Kiwi8
Deluxe Member
yes wifi.
Maybe some android box that can download android apps from Google Play Store?
gregory_choo
Thanks bro.
may be it is not the right place to mention this:
it is very expensive now to buy pc receiver card.
the cheaper way is to get usb receiver or stand alone box.
usb receivers cost less than $40
dvb t2 receiver box less than $30
singmob
Can connect hp/tablet via hdmi cable to monitor also. If supported.
manifold
USB DVB-T2 tuner that supports surround sound?
As indicated in the title, any recommendations that are compatible with tvheadend, kodi, nextpvr? Thanks!
